Cosparse Analysis Modeling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the past decade there has been a great interest in a synthesis-based model for signals, based on sparse and redundant representations. This work considers an alternative analysis-based model, where an analysis operator multiplies the signal, leading to a cosparse outcome. We consider this analysis model, in the context of a generic missing data problem. Our work proposes a uniqueness result for the solution of this problem, based on properties of the analysis operator and the measurement matrix. A new greedy algorithm for solving the missing data problem is proposed along with theoretical study of the success of the algorithm and experimental results.
cosparse_analysis_spars11.pdf (135.8 Ko) Télécharger le fichier
inria-00587943 , version 1 (16-09-2011)
  • HAL Id : inria-00587943 , version 1
Sangnam Nam, Mike E. Davies, Michael Elad, Rémi Gribonval. Cosparse Analysis Modeling. Workshop on Signal Processing with Adaptive Sparse Structured Representations, Jun 2011, Edinburgh, United Kingdom. ⟨inria-00587943⟩
355 Consultations
228 Téléchargements
