Matching and Clustering: Two Steps Towards Object Modelling in Computer Vision - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The International Journal of Robotics Research Année : 1995
In this article, we present a general frame for a system of au tomatic modeling and recognition of 3D polyhedral objects. Such a system has many applications for robotics: e.g., recog nition, localization, and grasping. Here we focus on one main aspect of the system: when many images of one 3D object are taken from different unknown viewpoints, how to recognize those that represent the same aspect of the object? Briefly, is it possible to determine automatically if two images are similar or not? The two stages detailed in the article are the matching of two images and the clustering of a set of images. Matching consists of finding the common features of two images while no information is known about the image contents, the motion, or the calibration of the camera. Clustering consists of regrouping into sets the images representing a same aspect of the modeled objects. For both stages, experimental results on real images are shown.
10.1.1.36.2263.pdf (381.85 Ko) Télécharger le fichier
inria-00590038 , version 1 (04-05-2011)
Patrick Gros. Matching and Clustering: Two Steps Towards Object Modelling in Computer Vision. The International Journal of Robotics Research, 1995, 14 (6), pp.633--642. ⟨10.1177/027836499501400608⟩. ⟨inria-00590038⟩
87 Consultations
381 Téléchargements
