New interface
Conference papers
Integrating geometric and photometric information for image retrieval
Cordelia Schmid 1 Andrew Zisserman 2 Roger Mohr 1
1 MOVI - Modeling, localization, recognition and interpretation in computer vision
GRAVIR - IMAG - Laboratoire d'informatique GRAphique, VIsion et Robotique de Grenoble, Inria Grenoble - Rhône-Alpes, CNRS - Centre National de la Recherche Scientifique : FR71
Abstract : We describe two image matching techniques that owe their success to a combination of geometric and photometric constraints. In the first, images are matched under similarity transformations by using local intensity invariants and semi-local geometric constraints. In the second, 3D curves and lines are matched between images using epipolar geometry and local photometric constraints. Both techniques are illustrated on real images. We show that these two techniques may be combined and are complementary for the application of image retrieval from an image database. Given a query image, local intensity invariants are used to obtain a set of potential candidate matches from the database. This is very efficient as it is implemented as an indexing algorithm. Curve matching is then used to obtain a more significant ranking score. It is shown that for correctly retrieved images many curves are matched, whilst incorrect candidates obtain very low ranking.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00590102
Contributor : Perception team Connect in order to contact the contributor
Submitted on : Tuesday, May 3, 2011 - 9:19:58 AM
Last modification on : Friday, February 4, 2022 - 3:30:12 AM
Links full text
Identifiers
Collections
Citation
Cordelia Schmid, Andrew Zisserman, Roger Mohr. Integrating geometric and photometric information for image retrieval. International Workshop on Shape, Contour and Grouping in Computer Vision, May 1998, Torre Artale, Italy. pp.217--233, ⟨10.1007/3-540-46805-6_13⟩. ⟨inria-00590102⟩
Share
Metrics
Record views
132
