On-line Hand-Eye Calibration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
In this paper, we address the problem of hand-eye calibration of arobot mounted video camera. In a first time, we derive a new linear formulation of the problem. This allows an algebraic analysis of the cases that usual approaches do not consider. In a second time, we extend this new formulation into an on-line hand-eye calibration method. This method allows to get rid of the calibration object required by the standard approaches and use unknown scenes instead. Finally, experimental results validate both methods.
3dim99.pdf (260.52 Ko) Télécharger le fichier
inria-00590109 , version 1 (03-05-2011)
Nicolas Andreff, Radu Horaud, Bernard Espiau. On-line Hand-Eye Calibration. 2nd International Conference on 3-D Digital Imaging and Modeling (3DIM'99), National Research Council of Canada, Oct 1999, Ottawa, Canada. pp.430--436, ⟨10.1109/IM.1999.805374⟩. ⟨inria-00590109⟩
243 Consultations
2087 Téléchargements
