Conference papers
A Language for Audiovisual Template Specification and Recognition
Abstract : We address the issue of detecting automatically occurrences of high level patterns in audiovisual documents. These patterns correspond to recurring sequences of shots, which are considered as first class entities by documentalists, and used for annotation and retrieval. We introduce a language for specifying these patterns, based on an extension of Allen's algebra with the regular expression operator +, which denotes an iteration of arbitrary length. We propose a formulation of this pattern language using the constraint satisfaction framework, in which templates are represented as constraint problems. We propose an efficient representation of domains (all subsequences of a given graph) and filtering methods for the Allen constraints. We illustrate the resulting system on a corpus of real world news broadcast examples.
Document type :
Conference papers
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/inria-00590131
Contributor : Perception team Connect in order to contact the contributor
Submitted on : Tuesday, May 3, 2011 - 9:24:41 AM
Last modification on : Sunday, June 26, 2022 - 9:54:40 AM
Long-term archiving on: : Friday, November 9, 2012 - 10:21:17 AM
File
carrive-00c-1.pdf
Identifiers
Citation
Jean Carrive, Pierre Roy, Francois Pachet, Rémi Ronfard. A Language for Audiovisual Template Specification and Recognition. 6th International Conference on Principles and Practice of Constraint Programming (CP '00), Sep 2000, Singapore, Singapore. pp.128--142, ⟨10.1007/3-540-45349-0_11⟩. ⟨inria-00590131⟩
Share
Metrics
Record views
133
Files downloads
112
