Detection and Avoidance of Semi-Transparent Obstacles using a Collective-Reward Based Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Most of the computer and robot-vision algorithms are designed mainly for opaque objects and non-opaque objects have received less attention, in spite of them being omnipresent in man-made environments. With an increasing usage of such objects, especially those made of glass, plastic etc., it becomes necessarily important to detect this class of objects while building a robot navigation system. Obstacle avoidance forms a primary yet challenging task in mobile robot navigation. The main objective of this paper is to present an algorithm to detect and avoid obstacles that are made of semi-transparent materials, such as plastic or glass. The algorithm makes use of a technique called the collective-reward based approach to detect such objects from single images captured by an uncalibrated camera in a live video stream. Random selection techniques are incorporated in the method to make the algorithm run in real-time. A mobile robot then uses the information after detection to perform an obstacle avoidance maneuver. Experiments were conducted on a real robot to test the efficacy of the algorithm.
Fichier non déposé
inria-00590278 , version 1 (03-05-2011)
Kompella Varun Raj, Peter Sturm. Detection and Avoidance of Semi-Transparent Obstacles using a Collective-Reward Based Approach. ICRA 2011 - IEEE International Conference on Robotics and Automation, May 2011, Shanghai, China. pp.3469-3474, ⟨10.1109/ICRA.2011.5980089⟩. ⟨inria-00590278⟩
137 Consultations
0 Téléchargements
