3D Structures Inference from Images Sequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Pattern Recognition and Artificial Intelligence Année : 1991
We prove here that the observation of occluding contours together with a movement of the camera permits the reconstruction of an observed surface. This result is demonstrated under very light constraints, generalizing previous results. Thus, the technique presented can be applied with any movement of the camera, under perspective projection, with surface C1 by parts or even with lines of discontinuity. It allows recovery of the structure of three-dimensional shapes with complex surfaces.
Fichier non déposé
inria-00590284 , version 1 (03-05-2011)
Emmanuel Arbogast, Roger Mohr. 3D Structures Inference from Images Sequences. International Journal of Pattern Recognition and Artificial Intelligence, 1991, 5 (5), pp.749-764. ⟨10.1142/S0218001491000430⟩. ⟨inria-00590284⟩
Collections
UGA
9 Consultations
0 Téléchargements
