Journal articles
Proving Weak Properties of Rewriting
Isabelle Gnaedig 1 Hélène Kirchner 2
1 CARTE - Theoretical adverse computations, and safety
Inria Nancy - Grand Est, LORIA - FM - Department of Formal Methods
Abstract : In rule-based programming, properties of programs, such as termination, are in general considered in their strong acceptance i.e., on every computation branch. But in practice, they may hold in their weak acceptance only i.e., on at least one computation branch. Moreover, weak properties are often enough to ensure that programs give the expected result. There are very few results to handle weak properties of rewriting. We address here two of them: termination and reducibility to a constructor form, in a unified framework allowing us to prove them inductively. Proof trees are developed, which simulate rewriting trees by narrowing and abstracting subterms. Our technique is constructive in the sense that proof trees can be used to infer an evaluation strategy for any given input: the right computation branch is developed without using a costly breadth-first strategy nor backtracking.
Document type :
Journal articles
Complete list of metadata
Cited literature [47 references]  Display  Hide  Download
https://hal.inria.fr/inria-00592271
Contributor : Isabelle Gnaedig Connect in order to contact the contributor
Submitted on : Friday, September 14, 2018 - 2:10:03 PM
Last modification on : Saturday, June 25, 2022 - 7:39:39 PM
Long-term archiving on: : Saturday, December 15, 2018 - 2:34:39 PM
File
weak-tcs-revision2.pdf
Identifiers
Collections
Citation
Isabelle Gnaedig, Hélène Kirchner. Proving Weak Properties of Rewriting. Theoretical Computer Science, Elsevier, 2011, 412, pp.4405-4438. ⟨10.1016/j.tcs.2011.04.028⟩. ⟨inria-00592271⟩
Share
Metrics
Record views
143
Files downloads
59
