Numerical Computation of the Large Deviation Multifractal Spectrum - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1996
We propose a kernel method for the estimation of the large deviation multifractal spectrum, and report on some preliminary results.
Numerical_Computation_of_the_Large_Deviation_Multifractal_Spectrum.pdf (4.09 Mo) Télécharger le fichier
inria-00593323 , version 1 (13-05-2011)
  • HAL Id : inria-00593323 , version 1
Jacques Lévy Véhel. Numerical Computation of the Large Deviation Multifractal Spectrum. CFIC'96 - Chaos and Fractals in Chemical Engineering, Sep 1996, Rome, Italy. ⟨inria-00593323⟩
Collections
INRIA INRIA2
92 Consultations
78 Téléchargements
