Towards a communication free coordination for multi-robot exploration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Olivier Simonin
Frontier-based exploration method are known to be efˇcient for multi-robot exploration systems. In this paper, we propose a novel, computationally inexpensive, frontier allocation method favoring a well balanced spatial distribution of robots in the environment. It is based on the computation of a position criteria. The position of a robot towards a frontier is deˇned by the number of robots closer to the frontier. Distances to frontiers are computed using a wavefront propagation from each frontier. The local minimum free potential ˇelds, thus created, are also used for navigation achieved by descending the potential ˇeld gradient. Comparisons with existing approaches in simulation demonstrated the efˇciency of our algorithm and experiments on robots validated the navigation method.
Bautin-toward-a-com.PDF (395.46 Ko) Télécharger le fichier
inria-00599605 , version 1 (10-06-2011)
  • HAL Id : inria-00599605 , version 1
Antoine Bautin, Olivier Simonin, François Charpillet. Towards a communication free coordination for multi-robot exploration. 6th National Conference on Control Architectures of Robots, INRIA Grenoble Rhône-Alpes, May 2011, Grenoble, France. 8 p. ⟨inria-00599605⟩
292 Consultations
527 Téléchargements
