Two FCA-Based Methods for Mining Gene Expression Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Gene expression data are numerical and describe the level of expression of genes in different situations, thus featuring behaviour of the genes. Two methods based on FCA (Formal Concept Analysis) are considered for clustering gene expression data. The first one is based on interordinal scaling and can be realized using standard FCA algorithms. The second method is based on pattern structures and needs adaptations of standard algorithms to computing with interval algebra. The two methods are described in details and discussed. The second method is shown to be more computationally efficient and providing more readable results. Experiments with gene expression data are discussed.
inria-00600200 , version 1 (14-06-2011)
Mehdi Kaytoue, Sébastien Duplessis, Sergei O. Kuznetsov, Amedeo Napoli. Two FCA-Based Methods for Mining Gene Expression Data. Formal Concept Analysis, 7th International Conference, ICFCA 2009, Apr 2009, Darmstadt, Germany. pp.251-266, ⟨10.1007/978-3-642-01815-2_19⟩. ⟨inria-00600200⟩
105 Consultations
0 Téléchargements
