BlobCR: Efficient Checkpoint-Restart for HPC Applications on IaaS Clouds using Virtual Disk Image Snapshots - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Infrastructure-as-a-Service (IaaS) cloud computing is gaining significant interest in industry and academia as an alternative platform for running scientific applications. Given the dynamic nature of IaaS clouds and the long runtime and resource utilization of such applications, an efficient checkpoint-restart mechanism becomes paramount in this context. This paper proposes a solution to the aforementioned challenge that aims at minimizing the storage space performance overhead of checkpoint-restart. We introduce a framework that combines checkpoint-restart protocols at guest level with virtual machine (VM) disk-image multi-snapshotting and multi-deployment at host level in order to efficiently capture and potentially roll back the complete state of the application, including file system modifications. Experiments on the G5K testbed show substantial improvement for MPI applications over existing approaches, both for the case when customized checkpointing is available at application level and the case when it needs to be handled at process level.
paper.pdf (193.57 Ko) Télécharger le fichier
inria-00601865 , version 1 (16-08-2011)
Bogdan Nicolae, Franck Cappello. BlobCR: Efficient Checkpoint-Restart for HPC Applications on IaaS Clouds using Virtual Disk Image Snapshots. SC'11: The 24th International Conference for High Performance Computing, Networking, Storage and Analysis, Nov 2011, Seattle, United States. pp.34:1-34:12, ⟨10.1145/2063384.2063429⟩. ⟨inria-00601865⟩
363 Consultations
1938 Téléchargements
