Gesture-based design of 2D contours: an alternative to sketching? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In addition to being a very expressive media, 2D sketches representing the contour of a shape are commonly used as a basis for 3D sketch-based modeling. This paper investigates an alternative to the standard way of creating such sketches: instead of carefully following the contour with a pen and erasing or over-sketching, the user progressively shapes the contour from a simple input curve, only through intuitive deformation gestures. No menus or sliders are used. This is achieved by providing an automatic selection mechanism between a minimal set of deformation operators, inspired from Michael Leyton's perceptual theory of shapes. The shape representation and the active operator parameters are kept transparent to the user. This enables user to focus on the design and makes the system immediately usable by anybody. We validate this new paradigm through a user study that includes a comparison with standard sketching.
Mots clés
gesture-based_design.pdf (1.04 Mo) Télécharger le fichier
sbim.avi (9.72 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
inria-00606353 , version 1 (06-07-2011)
inria-00606353 , version 2 (06-11-2011)
Thomas Delame, Jean-Claude Léon, Marie-Paule Cani, Renaud Blanch. Gesture-based design of 2D contours: an alternative to sketching?. SBIM 2011 - International Symposium on Sketch-Based Interfaces and Modeling, Eurographics, Aug 2011, Vancouver, Canada. pp.63-70, ⟨10.1145/2021164.2021176⟩. ⟨inria-00606353v2⟩
604 Consultations
442 Téléchargements
