Filtering Solid Gabor Noise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2011
Solid noise is a fundamental tool in computer graphics. Surprisingly, no existing noise function supports both high-quality antialiasing and continuity across sharp edges. In this paper we show that a slicing approach is required to preserve continuity across sharp edges, and we present a new noise function that supports anisotropic filtering of sliced solid noise. This is made possible by individually filtering the slices of Gabor kernels, which requires the proper treatment of phase. This in turn leads to the introduction of the phase-augmented Gabor kernel and random-phase Gabor noise, our new noise function. We demonstrate that our new noise function supports both high-quality anti-aliasing and continuity across sharp edges, as well as anisotropy.
paper_0049_preprint.pdf (3.45 Mo) Télécharger le fichier
paper_0049_code/LICENSE.txt (2.92 Ko) Télécharger le fichier
paper_0049_code/README.txt (35 B) Télécharger le fichier
paper_0049_code/doc/documentation.html (10.76 Ko) Télécharger le fichier
paper_0049_code/precompiled/linux/filtering_solid_gabor_noise (1.49 Mo) Télécharger le fichier
paper_0049_code/precompiled/linux/filtering_solid_gabor_noise.frag (8.85 Ko) Télécharger le fichier
paper_0049_code/precompiled/linux/filtering_solid_gabor_noise.vert (840 B) Télécharger le fichier
paper_0049_code/precompiled/linux/filtering_solid_gabor_noise_glsl120.frag (9.52 Ko) Télécharger le fichier
paper_0049_code/precompiled/linux/filtering_solid_gabor_noise_glsl120.vert (952 B) Télécharger le fichier
paper_0049_code/precompiled/macosx/filtering_solid_gabor_noise (1.29 Mo) Télécharger le fichier
paper_0049_code/precompiled/macosx/filtering_solid_gabor_noise.frag (8.85 Ko) Télécharger le fichier
paper_0049_code/precompiled/macosx/filtering_solid_gabor_noise.vert (840 B) Télécharger le fichier
paper_0049_code/precompiled/macosx/filtering_solid_gabor_noise_glsl120.frag (9.52 Ko) Télécharger le fichier
paper_0049_code/precompiled/macosx/filtering_solid_gabor_noise_glsl120.vert (952 B) Télécharger le fichier
paper_0049_code/precompiled/windows/filtering_solid_gabor_noise.exe (498.5 Ko) Télécharger le fichier
paper_0049_code/precompiled/windows/filtering_solid_gabor_noise.frag (8.85 Ko) Télécharger le fichier
paper_0049_code/precompiled/windows/filtering_solid_gabor_noise.vert (840 B) Télécharger le fichier
paper_0049_code/precompiled/windows/filtering_solid_gabor_noise_glsl120.frag (9.52 Ko) Télécharger le fichier
paper_0049_code/precompiled/windows/filtering_solid_gabor_noise_glsl120.vert (952 B) Télécharger le fichier
paper_0049_code/precompiled/windows/glut32.dll (232 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/AntPerfTimer.h (1.98 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/AntTweakBar.h (12.42 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/C.includecache (633 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/CXX.includecache (6.56 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/DependInfo.cmake (2.4 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/LoadOGL.cpp.o (40.48 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/TwBar.cpp.o (530.45 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/TwColors.cpp.o (8.24 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/TwEventGLUT.c.o (3.13 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/TwFonts.cpp.o (112.25 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/TwMgr.cpp.o (873.26 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/TwOpenGL.cpp.o (104.44 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/TwPrecomp.cpp.o (935 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/build.make (25.13 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/cmake_clean.cmake (592 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/cmake_clean_target.cmake (43 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/depend.internal (5.58 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/depend.make (3.87 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/flags.make (647 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/link.txt (396 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/AntTweakBar.dir/progress.make (169 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/CMakeDirectoryInformation.cmake (954 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeFiles/progress.marks (2 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/CMakeLists.txt (1.31 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/License.txt (894 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/LoadOGL.cpp (13.81 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/LoadOGL.h (24.36 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/MiniGLUT.h (4.82 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/TwBar.cpp (279.21 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/TwBar.h (18.66 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/TwColors.cpp (4.31 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/TwColors.h (2.84 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/TwEventGLUT.c (4.17 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/TwFonts.cpp (287.42 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/TwFonts.h (1.81 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/TwGraph.h (2.4 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/TwMgr.cpp (226.33 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/TwMgr.h (20.39 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/TwOpenGL.cpp (27.22 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/TwOpenGL.h (3.97 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/TwPrecomp.cpp (23 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/TwPrecomp.h (2.22 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/cmake_install.cmake (1.19 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/libAntTweakBar.a (1.76 Mo) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/FontChars.txt (1.76 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/FontLargeAA.pgm (85.09 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/FontNormal.pgm (63.84 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/FontNormalAA.pgm (72 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/FontSmall.pgm (42.94 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/TwXCursors.h (92.68 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/cur00000.cur (326 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/cur00001.cur (326 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/cur00002.cur (326 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/cur00003.cur (326 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/cur00004.cur (326 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/cur00005.cur (326 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/cur00006.cur (326 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/cur00007.cur (326 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/cur00008.cur (326 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/cur00009.cur (326 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/cur00010.cur (326 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/cur00011.cur (326 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/cur00012.cur (326 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/cur00013.cur (326 B) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/curs00.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/curs01.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/curs02.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/curs03.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/curs04.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/curs05.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/curs06.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/curs07.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/curs08.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/curs09.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/curs10.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/curs11.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/curs12.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/curs13.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/mask00.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/mask01.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/mask02.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/mask03.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/mask04.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/mask05.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/mask06.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/mask07.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/mask08.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/mask09.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/mask10.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/mask11.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/mask12.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/res/mask13.pbm (2.06 Ko) Télécharger le fichier
paper_0049_code/src/AntTweakBar/resource.h (1010 B) Télécharger le fichier
paper_0049_code/src/CMakeLists.txt (2.24 Ko) Télécharger le fichier
paper_0049_code/src/GLEW/CMakeFiles/CMakeDirectoryInformation.cmake (938 B) Télécharger le fichier
paper_0049_code/src/GLEW/CMakeFiles/GLEW.dir/C.includecache (630 B) Télécharger le fichier
paper_0049_code/src/GLEW/CMakeFiles/GLEW.dir/DependInfo.cmake (535 B) Télécharger le fichier
paper_0049_code/src/GLEW/CMakeFiles/GLEW.dir/build.make (5.4 Ko) Télécharger le fichier
paper_0049_code/src/GLEW/CMakeFiles/GLEW.dir/cmake_clean.cmake (238 B) Télécharger le fichier
paper_0049_code/src/GLEW/CMakeFiles/GLEW.dir/cmake_clean_target.cmake (36 B) Télécharger le fichier
paper_0049_code/src/GLEW/CMakeFiles/GLEW.dir/depend.internal (284 B) Télécharger le fichier
paper_0049_code/src/GLEW/CMakeFiles/GLEW.dir/depend.make (299 B) Télécharger le fichier
paper_0049_code/src/GLEW/CMakeFiles/GLEW.dir/flags.make (253 B) Télécharger le fichier
paper_0049_code/src/GLEW/CMakeFiles/GLEW.dir/glew.c.o (617.24 Ko) Télécharger le fichier
paper_0049_code/src/GLEW/CMakeFiles/GLEW.dir/link.txt (81 B) Télécharger le fichier
paper_0049_code/src/GLEW/CMakeFiles/GLEW.dir/progress.make (22 B) Télécharger le fichier
paper_0049_code/src/GLEW/CMakeFiles/progress.marks (2 B) Télécharger le fichier
paper_0049_code/src/GLEW/CMakeLists.txt (141 B) Télécharger le fichier
paper_0049_code/src/GLEW/GL/glew.h (774.35 Ko) Télécharger le fichier
paper_0049_code/src/GLEW/GL/glxew.h (58.88 Ko) Télécharger le fichier
paper_0049_code/src/GLEW/GL/wglew.h (54.02 Ko) Télécharger le fichier
paper_0049_code/src/GLEW/cmake_install.cmake (1.19 Ko) Télécharger le fichier
paper_0049_code/src/GLEW/glew.c (737.92 Ko) Télécharger le fichier
paper_0049_code/src/GLEW/libGLEW.a (690.43 Ko) Télécharger le fichier
paper_0049_code/src/filtering_solid_gabor_noise.cpp (14.96 Ko) Télécharger le fichier
paper_0049_code/src/filtering_solid_gabor_noise.frag (8.85 Ko) Télécharger le fichier
paper_0049_code/src/filtering_solid_gabor_noise.vert (840 B) Télécharger le fichier
paper_0049_code/src/filtering_solid_gabor_noise_glsl120.frag (9.52 Ko) Télécharger le fichier
paper_0049_code/src/filtering_solid_gabor_noise_glsl120.vert (952 B) Télécharger le fichier
paper_0049_code/src/glut/GL/glut.h (27.02 Ko) Télécharger le fichier
paper_0049_code/src/glut/README-win32.txt (25.83 Ko) Télécharger le fichier
paper_0049_code/src/glut/glut.def (2.24 Ko) Télécharger le fichier
paper_0049_code/src/glut/glut32.dll (232 Ko) Télécharger le fichier
paper_0049_code/src/glut/glut32.lib (28.05 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material.html (17.46 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_a1.avi (3.39 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_a2.avi (5.5 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_a2_unf.avi (5.68 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_a2_vs_d2_iso.avi (5.63 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_b1.avi (3.76 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_b2.avi (5.99 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_b2_unf.avi (6.16 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_b2_vs_d2_iso.avi (6.04 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_c1.avi (3.57 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_c1_iso.avi (3.87 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_c2.avi (5.84 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_c2_iso.avi (6.7 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_c2_iso_unf.avi (6.89 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_c2_iso_vs_d2_iso.avi (6.88 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_c2_unf.avi (6.1 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_c2_vs_d2.avi (5.81 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_d1.avi (3.37 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_d1_iso.avi (3.75 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_d2.avi (5.77 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_d2_iso.avi (6.44 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_d2_iso_unf.avi (6.61 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig1_d2_unf.avi (6 Mo) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6_c1.png (206.17 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6_c1_vs_c4.gif (347.59 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6_c2.png (217.98 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6_c2_vs_c4.gif (357.01 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6_c3.png (215.48 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6_c3_vs_c4.gif (352.76 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6_c4.png (203.62 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6_c_geom.png (87.66 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6_d1.png (418.62 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6_d1_vs_d4.gif (523.37 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6_d2.png (449.41 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6_d2_vs_d4.gif (533.15 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6_d3.png (456.23 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6_d3_vs_d4.gif (526.74 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6_d4.png (443.85 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6_d_geom.png (70.75 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6bis_c1.png (236.51 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6bis_c1_vs_c4.gif (388.24 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6bis_c2.png (248.83 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6bis_c2_vs_c4.gif (396.26 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6bis_c3.png (243.13 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6bis_c3_vs_c4.gif (394.28 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6bis_c4.png (230.92 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6bis_d1.png (164.57 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6bis_d1_vs_d4.gif (224.26 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6bis_d2.png (181.5 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6bis_d2_vs_d4.gif (229.78 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6bis_d3.png (224.87 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6bis_d3_vs_d4.gif (237.31 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/fig6bis_d4.png (214.92 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/empty.png (242 B) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_a1.png (5.72 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_a2.png (3.96 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_a2_unf.png (3.97 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_a2_vs_d2_iso.png (4.3 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_b1.png (5.88 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_b2.png (3.78 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_b2_unf.png (3.77 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_b2_vs_d2_iso.png (4.3 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_c1.png (5.76 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_c1_iso.png (5.86 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_c2.png (3.53 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_c2_iso.png (3.85 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_c2_iso_unf.png (3.81 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_c2_iso_vs_d2_iso.png (4.43 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_c2_unf.png (3.47 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_c2_vs_d2.png (3.71 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_d1.png (5.49 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_d1_iso.png (5.88 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_d2.png (3.59 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_d2_iso.png (4.19 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_d2_iso_unf.png (4.18 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig1_d2_unf.png (3.55 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6_c1.png (25.84 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6_c1_vs_c4.gif (30.1 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6_c2.png (27.28 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6_c2_vs_c4.gif (30.6 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6_c3.png (26.97 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6_c3_vs_c4.gif (30.33 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6_c4.png (25.51 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6_c_geom.png (4.54 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6_d1.png (34.27 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6_d1_vs_d4.gif (32.93 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6_d2.png (35.05 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6_d2_vs_d4.gif (32.79 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6_d3.png (34.94 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6_d3_vs_d4.gif (32.41 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6_d4.png (34.81 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6_d_geom.png (7.01 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6bis_c1.png (30.01 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6bis_c1_vs_c4.gif (32.83 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6bis_c2.png (31.4 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6bis_c2_vs_c4.gif (33.77 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6bis_c3.png (30.9 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6bis_c3_vs_c4.gif (33.48 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6bis_c4.png (28.94 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6bis_d1.png (16.75 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6bis_d1_vs_d4.gif (16.67 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6bis_d2.png (17.66 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6bis_d2_vs_d4.gif (16.86 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6bis_d3.png (18.46 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6bis_d3_vs_d4.gif (16.61 Ko) Télécharger le fichier
paper_0049_supplemental_material/paper_0049_supplemental_material/thumbnails/fig6bis_d4.png (18.32 Ko) Télécharger le fichier
paper_0049_video.mov (78.4 Mo) Télécharger le fichier
suppl_CW605.pdf (335.69 Ko) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Autre
Format : Vidéo
Format : Autre
inria-00606907 , version 1 (07-07-2011)
  • HAL Id : inria-00606907 , version 1
Ares Lagae, George Drettakis. Filtering Solid Gabor Noise. ACM Transactions on Graphics, 2011, SIGGRAPH Conference Proceedings, 30 (3). ⟨inria-00606907⟩
Collections
INRIA INRIA2
216 Consultations
430 Téléchargements
