Uniform hypothesis testing for finite-valued stationary processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Statistics Année : 2014
Daniil Ryabko
  • Fonction : Auteur correspondant
  • PersonId : 848126
Connectez-vous pour contacter l'auteur
Given a discrete-valued sample $X_1,\dots,X_n$ we wish to decide whether it was generated by a distribution belonging to a family $H_0$, or it was generated by a distribution belonging to a family $H_1$. In this work we assume that all distributions are stationary ergodic, and do not make any further assumptions (e.g. no independence or mixing rate assumptions). We would like to have a test whose probability of error (both Type I and Type II) is uniformly bounded. More precisely, we require that for each $\epsilon$ there exist a sample size $n$ such that probability of error is upper-bounded by $\epsilon$ for samples longer than $n$. We find some necessary and some sufficient conditions on $H_0$ and $H_1$ under which a consistent test (with this notion of consistency) exists. These conditions are topological, with respect to the topology of distributional distance.
1uf_arx.pdf (133.53 Ko) Télécharger le fichier
inria-00610009 , version 1 (20-07-2011)
inria-00610009 , version 2 (26-12-2014)
Daniil Ryabko. Uniform hypothesis testing for finite-valued stationary processes. Statistics, 2014, 48 (1), pp.121-128. ⟨10.1080/02331888.2012.719511⟩. ⟨inria-00610009v2⟩
177 Consultations
246 Téléchargements
