Coquet: a Coq library for verifying hardware - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
Thomas Braibant
  • Fonction : Auteur
  • PersonId : 860237
We propose a new library to model and verify hardware circuits in the Coq proof assistant. This library allows one to easily build circuits by following the usual pen-and-paper diagrams. We define a deep-embedding: we use a (dependently typed) data-type that models the architecture of circuits, and a meaning function. We propose tactics that ease the reasoning about the behavior of the circuits, and we demonstrate that our approach is practicable by proving the correctness of various circuits: a text-book divide and conquer adder of parametric size, some higher-order combinators of circuits, and some sequential circuits: a buffer, and a register.
main.pdf (274.55 Ko) Télécharger le fichier
inria-00611757 , version 1 (22-08-2011)
  • HAL Id : inria-00611757 , version 1
  • ARXIV : 1108.4253
Thomas Braibant. Coquet: a Coq library for verifying hardware. 2011. ⟨inria-00611757⟩
142 Consultations
768 Téléchargements
