Multifractal Segmentation of Remotely Sensed Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 1994
Remotely sensed images are typically highly textured. In this work, segmentation of such images is performed based on local/global regularity criteria within the frame of multifractal analysis. Numerical experiments show that such an approach indeed yields meaningful results.
Fichier non déposé
inria-00613972 , version 1 (08-08-2011)
  • HAL Id : inria-00613972 , version 1
Jacques Lévy Véhel. Multifractal Segmentation of Remotely Sensed Images. 1994. ⟨inria-00613972⟩
Collections
INRIA INRIA2
93 Consultations
0 Téléchargements
