About lacunarity, some links between fractal and integral geometry, and an application to texture segmentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1990
Jacques Lévy-Vehel
  • Fonction : Auteur
  • PersonId : 902488
In this work, we apply two techniques for segmentation of different states of one texture (e.g. deformations of an homogeneous texture) : - fractal geometry, that deals with the analysis of complex irregular shapes which cannot well be described by the classical Euclidean geometry - integral geometry, that treats sets globally and allows to introduce robust measures. We focus on the study of two parameters, lacunarity and Favard length, and proove a theoretical link between them. As an application, we are able to achieve automatic classification of lung diseases on the basis on SPECT images.
Fichier non déposé
inria-00614000 , version 1 (08-08-2011)
Jacques Lévy-Vehel. About lacunarity, some links between fractal and integral geometry, and an application to texture segmentation. ICCV'90 - Third International Conference on Computer Vision, Dec 1990, Osaka, Japan. pp.380-384, ⟨10.1109/ICCV.1990.139556⟩. ⟨inria-00614000⟩
Collections
INRIA INRIA2
44 Consultations
0 Téléchargements
