Biomanycores, open-source parallel code for many-core bioinformatics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Biomanycores is a collection of bioinformatics tools, designed to bridge the gap between researches in OpenCL/CUDA high-performance computing on GPU and other "manycore processors" and usual bioinformaticians and biologists.
bosc11.pdf (31.27 Ko) Télécharger le fichier
inria-00623390 , version 1 (14-09-2011)
  • HAL Id : inria-00623390 , version 1
Mathieu Giraud, Stéphane Janot, Jean-Frédéric Berthelot, Charles Deltel, Laetitia Jourdan, et al.. Biomanycores, open-source parallel code for many-core bioinformatics. Bioinformatics Open Source Conference (BOSC 2011), 2011, Vienne, Austria. ⟨inria-00623390⟩
792 Consultations
733 Téléchargements
