Semiparametric estimation of rigid transformations on compact Lie groups - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Myriam Vimond
  • Fonction : Auteur
  • PersonId : 844040
We study a simple model for the estimation of rigid transformations between noisy images. The transformations are supposed to belong to a compact Lie group, and a new matching criteria based on the Fourier transform is proposed. Consistency and asymptotic normality of the resulting estimators are studied. Some simulations are used to illustrate the methodology, and we describe potential applications of this approach to various image registration problems.
Autre [cs.OH]
mfca08_3_3.pdf (175.3 Ko) Télécharger le fichier
inria-00632877 , version 1 (16-10-2011)
  • HAL Id : inria-00632877 , version 1
Jérémie Bigot, Jean-Michel Loubes, Myriam Vimond. Semiparametric estimation of rigid transformations on compact Lie groups. 2nd MICCAI Workshop on Mathematical Foundations of Computational Anatomy, Oct 2008, New-York, United States. pp.92-104. ⟨inria-00632877⟩
137 Consultations
46 Téléchargements
