Partial amplitude synchronization detection in brain signals using Bayesian Gaussian mixture models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Physiology - Paris Année : 2011
Maxime Rio
  • Fonction : Auteur
  • PersonId : 861794
Axel Hutt
Bernard Girau
The present work investigates instantaneous synchronization in multivariate signals. It introduces a new method to detect subsets of synchronized time series that do not consider any baseline information. The method is based on a Bayesian Gaussian mixture model applied at each location of a time-frequency map. The work assesses the relevance of detected subsets by a stability measure. The application to Local Field Potentials measured during a visuo-motor experiment in monkeys reveals a subset of synchronized time series measured in the visual cortex.
inria-00633489 , version 1 (18-10-2011)
Maxime Rio, Axel Hutt, Matthias Munk, Bernard Girau. Partial amplitude synchronization detection in brain signals using Bayesian Gaussian mixture models. Journal of Physiology - Paris, 2011, 105 (1-3), pp.98-105. ⟨10.1016/j.jphysparis.2011.07.018⟩. ⟨inria-00633489⟩
218 Consultations
0 Téléchargements
