Statistical linear models in Procrustes shape space
Abstract : The configuration matrix of a set of labeled landmarks is one the most used shape representations. However, it is well-known that the configuration matrix is not invariant under translation, scaling and rotation. This problem is revisited in this work where a local tangent shape space characterization at a reference shape is obtained as the null space of the subspace spanned by the reference shape and the set of translation and rotation generators. This local linear description of the shape space allows us to compute mean and variance of shapes as well as apply classical mutivariate statistical techniques such as Principal Component Analysis. Our proposal is compared with previous approaches, such as the seminal work [1] and more recents works [2] and [3].
Type de document :
Communication dans un congrès
Xavier Pennec and Sarang Joshi. 1st MICCAI Workshop on Mathematical Foundations of Computational Anatomy: Geometrical, Statistical and Registration Methods for Modeling Biological Shape Variability, Oct 2006, Copenhagen, Denmark. pp.102-111, 2006
Liste complète des métadonnées
Littérature citée [11 références]  Voir  Masquer  Télécharger
https://hal.inria.fr/inria-00635901
Contributeur : Service Ist Inria Sophia Antipolis-Méditerranée / I3s <>
Soumis le : mercredi 26 octobre 2011 - 11:44:00
Dernière modification le : mercredi 26 octobre 2011 - 12:57:15
Document(s) archivé(s) le : dimanche 4 décembre 2016 - 23:09:44
Fichier
Bossa_MFCA06.pdf
Fichiers produits par l'(les) auteur(s)
  • HAL Id : inria-00635901, version 1
Collections
Citation
Matias Bossa, Salvador Olmos. Statistical linear models in Procrustes shape space. Xavier Pennec and Sarang Joshi. 1st MICCAI Workshop on Mathematical Foundations of Computational Anatomy: Geometrical, Statistical and Registration Methods for Modeling Biological Shape Variability, Oct 2006, Copenhagen, Denmark. pp.102-111, 2006. 〈inria-00635901〉
Métriques
Consultations de la notice
114
Téléchargements de fichiers
212
