Comparison of Model Averaging and Model Selection in Dose Finding Trials Analyzed by Nonlinear Mixed Effect Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue AAPS Journal Année : 2018
In drug development, pharmacometric approaches consist in identifying via a model selection (MS) process the model structure that best describes the data. However, making predictions using a selected model ignores model structure uncertainty, which could impair predictive performance. To overcome this drawback, model averaging (MA)takes into account the uncertainty across a set of candidate models by weighting them as a function of an information criterion. Our primary objective was to use clinical trial simulations (CTSs) to compare model selection (MS) with model averaging (MA) in dose-finding clinical trials, based on the AIC information criterion. A secondary aim of this analysis was to challenge the use of AIC by comparing MA and MS using 5 different information criteria. CTSs were based on a nonlinear mixed effects model characterizing the time course of visual acuity in wet age-related macular degeneration patients. Predictive performances of the modeling approaches were evaluated using 3 performance criteria focused on the main objectives of a phase II clinical trial. In this framework, MA adequately described the data and showed better predictive performance than MS, increasing the likelihood of accurately characterizing the dose-response relationship and defining the minimum effective dose. Moreover, regardless of the modeling approach, AIC was associated with the best predictive performances.
Manuscript_HALInserm.pdf (1.44 Mo) Télécharger le fichier
Supplement.pdf (805.25 Ko) Télécharger le fichier
inserm-01807517 , version 1 (04-06-2018)
Simon Buatois, Sebastian Ueckert, Nicolas Frey, Sylvie Retout, France Mentré. Comparison of Model Averaging and Model Selection in Dose Finding Trials Analyzed by Nonlinear Mixed Effect Models. AAPS Journal, 2018, 20 (3), pp.56. ⟨10.1208/s12248-018-0205-x⟩. ⟨inserm-01807517⟩
290 Consultations
487 Téléchargements
