The diffusion-simulated connectivity (DiSCo) dataset - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Data in Brief Année : 2021
The methodological development in the mapping of the brain structural connectome from diffusion-weighted magnetic resonance imaging (DW-MRI) has raised many hopes in the neuroscientific community. Indeed, the knowledge of the connections between different brain regions is fundamental to study brain anatomy and function. The reliability of the structural connectome is therefore of paramount importance. In the search for accuracy, researchers have given particular attention to linking white matter tractography methods – used for estimating the connectome – with information about the microstructure of the nervous tissue. The creation and validation of methods in this context were hampered by a lack of practical numerical phantoms. To achieve this, we created a numerical phantom that mimics complex anatomical fibre pathway trajectories while also accounting for microstructural features such as axonal diameter distribution, myelin presence, and variable packing densities. The substrate has a micrometric resolution and an unprecedented size of 1 cubic millimetre to mimic an image acquisition matrix of voxels. DW-MRI images were obtained from Monte Carlo simulations of spin dynamics to enable the validation of quantitative tractography. The phantom is composed of 12,196 synthetic tubular fibres with diameters ranging from 1.4 µm to 4.2 µm, interconnecting sixteen regions of interest. The simulated images capture the microscopic properties of the tissue (e.g. fibre diameter, water diffusing within and around fibres, free water compartment), while also having desirable macroscopic properties resembling the anatomy, such as the smoothness of the fibre trajectories. While previous phantoms were used to validate either tractography or microstructure, this phantom can enable a better assessment of the connectome estimation’s reliability on the one side, and its adherence to the actual microstructure of the nervous tissue on the other.
1-s2.0-S2352340921007113-main.pdf (1.15 Mo) Télécharger le fichier
Origine : Publication financée par une institution
inserm-03366969 , version 1 (05-10-2021)
Paternité - Pas d'utilisation commerciale - Pas de modification
Jonathan Rafael-Patino, Gabriel Girard, Raphaël Truffet, Marco Pizzolato, Emmanuel Caruyer, et al.. The diffusion-simulated connectivity (DiSCo) dataset. Data in Brief, 2021, 38, pp.1-7. ⟨10.1016/j.dib.2021.107429⟩. ⟨inserm-03366969⟩
171 Consultations
155 Téléchargements
