Challenges in Measurement of Spasticity in Neurological Disorders - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2013
Current challenges in the upper motor neuron syndrome (UMNS) management include identifying and establishing correct strategies to evaluate spasticity in clinical and research settings. There are a number of measures frequently used in a clinical environment. They are mainly qualitative tools that range from questionnaires to scales that are practical but imprecise. Alternative, quantitative measures that provide an accurate evaluation of spasticity are currently available for use, however they require specialist training and equipment. The advantage of quantitative assessments is that they can also differentiate between different components of spasticity and their contribution in the symptomatology. However, the use of these precise tools requires a longer time than is usually available in clinical practice. This chapter presents an overview of the different methods that exist to evaluate spasticity and proposes different management strategies. There is still a need to converge the efforts of researchers in different fields to develop accurate practical tools and algorithms that allow for precise evaluations in clinical practice.
Fichier non déposé
lirmm-00859370 , version 1 (07-09-2013)
Marta Pajaro-Blázquez, Paweł Maciejasz, John Mccamley, Ivan Collantes-Vallar, Dorin Copaci, et al.. Challenges in Measurement of Spasticity in Neurological Disorders. José L. Pons and Diego Torricelli. Emerging Therapies in Neurorehabilitation, 4, , pp.117-145, 2013, Biosystems & Biorobotics, 978-3-642-38555-1(Print);978-3-642-38556-8(Online). ⟨10.1007/978-3-642-38556-8_7⟩. ⟨lirmm-00859370⟩
243 Consultations
0 Téléchargements
