Spatial-Time Motifs Discovery - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Intelligent Data Analysis Année : 2020
Discovering motifs in time series data has been widely explored. Various techniques have been developed to tackle this problem. However, when it comes to spatial-time series, a clear gap can be observed according to the literature review. This paper tackles such a gap by presenting an approach to discover and rank motifs in spatial-time series, denominated Combined Series Approach (CSA). CSA is based on partitioning the spatial-time series into blocks. Inside each block, subsequences of spatial-time series are combined in a way that hash-based motif discovery algorithm is applied. Motifs are validated according to both temporal and spatial constraints. Later, motifs are ranked according to their entropy, the number of occurrences, and the proximity of their occurrences. The approach was evaluated using both synthetic and seismic datasets. CSA outperforms traditional methods designed only for time series. CSA was also able to prioritize motifs that were meaningful both in the context of synthetic data and also according to seismic specialists.
2020-09-ISA-CSA-V1.pdf (948.67 Ko) Télécharger le fichier
lirmm-02984969 , version 1 (01-11-2020)
Heraldo Borges, Murillo Dutra, Amin Bazaz, Rafaelli Coutinho, Fábio Perosi, et al.. Spatial-Time Motifs Discovery. Intelligent Data Analysis, 2020, 24 (5), pp.1121-1140. ⟨10.3233/IDA-194759⟩. ⟨lirmm-02984969⟩
97 Consultations
433 Téléchargements
