Variable size segmentation for efficient representation and querying of non-uniform time series datasets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Lamia Djebour
  • Fonction : Auteur
  • PersonId : 1119503
Reza Akbarinia
Florent Masseglia
Existing approaches for time series similarity computing are the core of many data analytics tasks. Given the considered data volumes, or simply the need for fast response times, they often rely on shorter representations, usually with information loss. This incurs approximate comparisons where precision is a major issue. We present and experimentally evaluate ASAX, a new approach for segmenting time series before their transformation into symbolic representations. ASAX reduces significantly the information loss incurred by possible splittings at different steps of the representation calculation, particularly for datasets with unbalanced (nonuniform) distributions. We provide theoretical guarantees on the lower bound of similarity measures, and our experiments illustrate that our method outperforms the state of the art, with significant gain in precision for datasets with unbalanced distributions.
Entropy-SAC.pdf (3.9 Mo) Télécharger le fichier
lirmm-03806053 , version 1 (07-10-2022)
Lamia Djebour, Reza Akbarinia, Florent Masseglia. Variable size segmentation for efficient representation and querying of non-uniform time series datasets. SAC 2022 - 37th ACM/SIGAPP Symposium on Applied Computing, Apr 2022, Virtual Event, United States. pp.395-402, ⟨10.1145/3477314.3507000⟩. ⟨lirmm-03806053⟩
47 Consultations
77 Téléchargements
