Deciding Hyperproperties Combined with Functional Specifications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study satisfiability for HyperLTL with a ∀*∃* quantifier prefix, known to be highly undecidable in general. HyperLTL can express system properties that relate multiple traces (so-called hyperproperties), which are often combined with trace properties that specify functional behavior on single traces. Following this conceptual split, we first define several safety and liveness fragments of ∀*∃* HyperLTL, and characterize the complexity of their (often much easier) satisfiability problem. We then add LTL trace properties as functional specifications. Though (highly) undecidable in many cases, this way of combining “simple” HyperLTL and arbitrary LTL also leads to interesting new decidable fragments. This systematic study of ∀*∃* fragments is complemented by a new (incomplete) algorithm for ∀∃*-HyperLTL satisfiability.
22-lics-deciding-hyperproperties.pdf (834.49 Ko) Télécharger le fichier
lirmm-03833578 , version 1 (20-09-2023)
Paternité
Raven Beutner, David Carral, Bernd Finkbeiner, Jana Hofmann, Markus Krötzsch. Deciding Hyperproperties Combined with Functional Specifications. LICS 2022 - 37th Annual ACM/IEEE Symposium on Logic in Computer Science, Aug 2022, Haifa, Israel. pp.1-13, ⟨10.1145/3531130.3533369⟩. ⟨lirmm-03833578⟩
49 Consultations
8 Téléchargements
