Integrating Machine Learning Model Ensembles to the SAVIME Database System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The integration of machine learning algorithms into database systems has brought new opportunities in different areas from indexing to query optimization. In this paper, we describe the integration of an approach for the automatic computation of model ensembles to answer a predictive query. We have extended the SAVIME multi-dimensional array DBMS by adding a new function to its query language and implementing the selection and allocation ensemble model dataflow into the query processing component of SAVIME. We show some initial experimental results depicting its performance against a pure Python implementation of the ensemble approach. Interestingly enough the C++ implementation within SAVIME is up to 4 times faster than its competitor.
Integrating Machine Learning Model Ensembles to SAVIME.pdf (772.98 Ko) Télécharger le fichier
lirmm-03850420 , version 1 (13-11-2022)
Anderson Chaves Silva, Patrick Valduriez, Fábio André Machado Porto. Integrating Machine Learning Model Ensembles to the SAVIME Database System. SBBD 2022 - Simpósio Brasileiro de Banco de Dados, Sep 2022, Buzios, Brazil. pp.232-238, ⟨10.5753/sbbd_estendido.2022.21870⟩. ⟨lirmm-03850420⟩
36 Consultations
41 Téléchargements
