kNN matrix profile for knowledge discovery from time series - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Data Mining and Knowledge Discovery Année : 2023
Reza Akbarinia
Florent Masseglia
Matrix Profile (MP) has been proposed as a powerful technique for knowledge extraction from time series. Several algorithms have been proposed for computing it, e.g., STAMP and STOMP. Currently, MP is computed based on 1NN search in all subsequences of the time series. In this paper, we claim that a kNN MP can be more useful than the 1NN MP for knowledge extraction, and propose an efficient technique to compute such a MP. We also propose an algorithm for parallel execution of kNN MP by using multiple cores of an off-the-shelf computer. We evaluated the performance of our solution by using multiple real datasets. The results illustrate the superiority of kNN MP for knowledge discovery compared to 1NN MP.
DMKD_Final_Version.pdf (5.33 Mo) Télécharger le fichier
lirmm-04225369 , version 1 (02-10-2023)
Paternité
Tanmoy Mondal, Reza Akbarinia, Florent Masseglia. kNN matrix profile for knowledge discovery from time series. Data Mining and Knowledge Discovery, 2023, 37 (3), pp.1055-1089. ⟨10.1007/s10618-022-00883-8⟩. ⟨lirmm-04225369⟩
19 Consultations
91 Téléchargements
