SoftED: Metrics for Soft Evaluation of Time Series Event Detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Time series event detection methods are evaluated mainly by standard classification metrics that focus solely on detection accuracy. However, inaccuracy in detecting an event can often result from its preceding or delayed effects reflected in neighboring detections. These detections are valuable to trigger necessary actions or help mitigate unwelcome consequences. In this context, current metrics are insufficient and inadequate for the context of event detection. There is a demand for metrics that incorporate both the concept of time and temporal tolerance for neighboring detections. This paper introduces SoftED metrics, a new set of metrics designed for soft evaluating event detection methods. They enable the evaluation of both detection accuracy and the degree to which their detections represent events. They improved event detection evaluation by associating events and their representative detections, incorporating temporal tolerance in over 36% of experiments compared to the usual classification metrics. SoftED metrics were validated by domain specialists that indicated their contribution to detection evaluation and method selection.
2304.00439.pdf (3.88 Mo) Télécharger le fichier
lirmm-04280618 , version 1 (11-11-2023)
Rebecca Salles, Janio Lima, Rafaelli Coutinho, Esther Pacitti, Florent Masseglia, et al.. SoftED: Metrics for Soft Evaluation of Time Series Event Detection. 2023. ⟨lirmm-04280618⟩
21 Consultations
15 Téléchargements
