Exploiting the Phase in Diffusion MRI for Microstructure Recovery: Towards Axonal Tortuosity via Asymmetric Diffusion Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Vidéo Année : 2015
Afficher
We derive the Ensemble Average Propagator (EAP) for the case of straight axons (White Matter tissue elongation) and for undulated axons having different tortuosity rates (WM tissue compression). We show that under the hypothesis of having both the Magnitude and Phase of the dMRI signal we can quantify the asymmetry of the EAP which is related to the rate of tortuosity variation in the compressed axon.
medihal-01358880 , version 1 (01-09-2016)
Paternité - Pas d'utilisation commerciale - Pas de modification
  • HAL Id : medihal-01358880 , version 1
Marco Pizzolato, Demian Wassermann, Timothé Boutelier, Rachid Deriche. Exploiting the Phase in Diffusion MRI for Microstructure Recovery: Towards Axonal Tortuosity via Asymmetric Diffusion Processes. 2015. ⟨medihal-01358880⟩
299 Consultations
32 Téléchargements
