Curvilinear Analysis and Approximation of Cardiac DTI In-Vivo - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2012
Diffusion Tensor MRI can be used to depict the anisotropy of tissue. Translation of this technique to moving objects such as the beating heart has recently become feasible, but remains a challenging task, often leading to high noise levels and limited accuracy. Ultimately, knowledge of the 3D fibre architecture of the myocardium invivo should allow for a better understanding of the cardiac function both in healthy and pathological situations. The main goal of the work presented in this thesis is to overcome the difficulties that such technology presents, by introducing a combination of image processing and analysis approaches. In particular, the characteristic ellipsoidal shape of the left ventricular chamber is used to introduce a shape-based prolate spheroidal coordinate frame that allows for comprehensive, robust and dedicated analysis of diffusion tensor data within the myocardial wall. It is shown that the description of this information is more compact in this coordinate frame. Furthermore, it is demonstrated that the acquisition limitations can be overcome by introducing an approximation scheme based on this coordinate frame. These techniques are tested on ex-vivo datasets to assess their fidelity and sensitivity. Finally, these techniques are applied in-vivo on a group of healthy volunteers, where 2D DTI slices of the LV were acquired at end diastole and end systole, using cardiac dedicated diffusion MR acquisition. Results demonstrate the advantages of using curvilinear coordinates both for the analysis and the approximation of cardiac DTI information. Resulting in-vivo fibre architectures were found to agree with previously reported studies on ex-vivo specimens. The outcome of this work can open the door for clinical applications and cardiac electrophysiology modelling, and improve the understanding of the left ventricular structure and dynamics.
PhDThesis-NicolasToussaint.pdf (51 Mo) Télécharger le fichier
tel-00846248 , version 1 (18-07-2013)
  • HAL Id : tel-00846248 , version 1
Nicolas Toussaint. Curvilinear Analysis and Approximation of Cardiac DTI In-Vivo. Medical Imaging. King's College London, 2012. English. ⟨NNT : ⟩. ⟨tel-00846248⟩
Collections
INRIA INRIA2
242 Consultations
618 Téléchargements
