Représentation des connaissances sémantiques lexicales de la Théorie Sens-Texte : conceptualisation, représentation, et opérationnalisation des définitions lexicographiques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
Meaning-Text Theory lexical semantic knowledge representation : conceptualization, representation, and operationalization of lexicographic definitions
We present our research in applying knowledge engineering to linguistic predicates and lexicographic definitions of the Meaning-Text Theory (MTT). We adopt a three-step methodology. 1. We first show how the MTT conceptualization should be extended to ease its formalization. We justify the need of defining a new graph-based deep semantic level. We define the notion of deep semantic unit types and its actantial structure, so that their hierarchical organization may correspond to a hierarchy of meanings, inside which actantial structures are inherited and specialized. We re-conceptualize lexicographic definitions at the deep semantic level, and at the level of dictionaries. Finally, we present a definition editor prototype based on graph direct manipulation, which will allow us, in future work, to integrate our formal model into explanatory combinatorial lexicographic projects. 2. We then propose a knowledge representation formalism (KR) adapted for this conceptualization. We demonstrate that Description Logics and the Conceptual Graphs formalism do not fit our needs. This leads us to construct a new knowledge representation formalism: the Unit Graphs formalism. 3. Finally, we operationalize the Unit Graphs formalism. We assign it a formal semantic model, which we create based on model theory and relational algebra. We then show that the reasoning decidability conditions match the intuitions that lexicographers have. We also provide an implementation using semantic web standards, which enable us to use existing architectures for sharing, interoperability, and knowledge querying over the web of lexical linked data.
Nous présentons une recherche en ingénierie des connaissances appliquée aux prédicats linguistiques et aux définitions lexicographiques de la théorie Sens-Texte (TST). Notre méthodologie comporte trois étapes. 1. Nous montrons en quoi la conceptualisation de la TST devrait être étendue pour faciliter sa formalisation. Nous justifions la nécessité de définir un niveau sémantique profond (SemP) à base de graphes. Nous y définissons la notion de type d'unité sémantique profonde et sa structure actancielle, de sorte que leur organisation hiérarchique puisse correspondre à une hiérarchie de sens au sein de laquelle ces structures actancielles sont héritées et spécialisées. Nous reconceptualisons les définitions lexicographiques au niveau SemP, et au niveau du dictionnaire. Finalement, nous présentons un prototype d'éditeur de définitions basé sur la manipulation directe de graphes. 2. Nous proposons un formalisme de représentation des connaissances adapté à cette conceptualisation. Nous démontrons que les logiques de description et le formalisme des Graphes Conceptuels ne sont pas adaptés, et nous construisons alors un nouveau formalisme, dit des Graphes d'Unités. 3. Nous étudions l'opérationnalisation du formalisme des Graphes d'Unités. Nous lui associons une sémantique formelle basée sur la théorie des modèles et l'algèbre relationnelle, et montrons que les conditions de décidabilité du raisonnement logique correspondent aux intuitions des lexicographes. Nous proposons également une implémentation du formalisme avec les standards du web sémantique, ce qui permet de profiter des architectures existantes pour l'interopérationnalisation sur le web des données lexicales liées.
2014NICE4043.pdf (3.77 Mo) Télécharger le fichier
tel-01071945 , version 2 (07-10-2014)
tel-01071945 , version 1 (06-04-2016)
  • HAL Id : tel-01071945 , version 2
Maxime Lefrançois. Représentation des connaissances sémantiques lexicales de la Théorie Sens-Texte : conceptualisation, représentation, et opérationnalisation des définitions lexicographiques. Autre [cs.OH]. Université Nice Sophia Antipolis, 2014. Français. ⟨NNT : 2014NICE4043⟩. ⟨tel-01071945v2⟩
826 Consultations
2319 Téléchargements
