Segmentation by example of 3D meshes
Segmentation de maillages 3D par l'exemple
In this dissertation, we present a new method to segment 3D models into their functional parts. The segmentation is performed by a transfer approach: a semantic-oriented segmentation of an object is calculated using a pre-segmented example model from the same class (chairs, humans, etc.). To this end, we adapted and extended the random walk segmentation method which allowed us to transform our problem into a problem of locating and matching seed faces. Our method consists of four fundamental steps: establishing correspondences between the example and the target model, localizing seeds to initialize regions in the target model, computing the segments and refining their boundaries in the target model. We decomposed our approach in two, taking into account similarity criteria which differ regarding the object type (rigid vs. articulated). The first approach is dedicated to rigid objects (chairs, airplanes, etc.), where the matching is based on rigid transformations to determine the best alignment between the functional parts of the compared objects. The second one focused on articulated objects (humans, quadrupeds, etc.), where coarse topological shape attributes are used in a skeleton-based approach to cover larger pose variations when computing correspondences between functional parts. We show through qualitative and quantitative evaluations that our method improves upon individual segmentation techniques and obtains results that are close to the co-segmentation techniques results with an important calculation time reduction.
Cette thèse présente une méthode de segmentation de modèles 3D en parties significatives ou fonctionnelles. La segmentation s’effectue par "transfert" d’une segmentation exemple : la segmentation d’un modèle est calculée en transférant les segments d’une segmentation exemple d’un objet appartenant à la même classe de modèles 3D. Pour ce faire, nous avons adapté et étendu la méthode de segmentation par les marches aléatoires et transformé notre problème en un problème de localisation et mise en correspondance de faces germes. Notre méthode comporte quatre étapes fondamentales : la mise en correspondance entre le modèle exemple et le modèle cible, la localisation automatique de germes sur le modèle cible pour initialiser les régions, le calcul des segments du modèle cible et l’amélioration de leurs frontières. En constatant que les critères de similarité diffèrent selon que les objets sont de type rigide (chaises, avions,…) ou de type articulé (humains, quadrupèdes,…), nous décomposons notre approche en deux. La première dédiée aux objets rigides, où la mise en correspondance est basée sur le calcul des transformations rigides afin d’aligner au mieux les parties significatives des deux objets comparés. La deuxième dédiée aux modèles articulés, où la mise en correspondance des parties fonctionnelles, présentant des variations de poses plus importantes, est basée sur des squelettes calculés via des diagrammes de Reeb. Nous montrons à travers des évaluations qualitatives et quantitatives que notre méthode obtient des résultats meilleurs que les techniques de segmentation individuelle et comparables aux techniques de co-segmentation avec un temps de calcul nettement inférieur.
Origin : Version validated by the jury (STAR)
