Annotation en rôles sémantiques du français en domaine spécifique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Domain-specific French Semantic Role Labeling
In this Natural Language Processing Ph. D. Thesis, we aim to perform semantic role labeling on French domain-specific texts. This task first disambiguates the sense of predicates in a given text and annotates its child chunks with semantic roles such as Agent, Patient or Destination. The task helps many applications in domains where annotated corpora exist, but is difficult to use otherwise. We first evaluate on the FrameNet corpus an existing method based on VerbNet, which explains why the method is domain-independant. We show that substantial improvements can be obtained. We first use syntactic information by handling the passive voice. Next, we use semantic informations by taking advantage of the selectional restrictions present in VerbNet. To apply this method to French, we first translate lexical resources. We first translate the WordNet lexical database. Next, we translate the VerbNet lexicon which is organized semantically using syntactic information. We obtain its translation, VerbeNet, by reusing two French verb lexicons (the Lexique-Grammaire and Les Verbes Français) and by manually modifying and reorganizing the resulting lexicon. Finally, once those building blocks are in place, we evaluate the feasibility of semantic role labeling of French and English in three specific domains. We study the pros and cons of using VerbNet and VerbeNet to annotate those domains before explaining our future work.
Cette thèse de Traitement Automatique des Langues a pour objectif l'annotation automatique en rôles sémantiques du français en domaine spécifique. Cette tâche désambiguïse le sens des prédicats d'un texte et annote les syntagmes liés avec des rôles sémantiques tels qu'Agent, Patient ou Destination. Elle aide de nombreuses applications dans les domaines où des corpus annotés existent, mais est difficile à utiliser quand ce n'est pas le cas. Nous avons d'abord évalué sur le corpus FrameNet une méthode existante d'annotation basée uniquement sur VerbNet et donc indépendante du domaine considéré. Nous montrons que des améliorations conséquentes peuvent être obtenues à la fois d'un point de vue syntaxique avec la prise en compte de la voix passive et d'un point de vue sémantique en utilisant les restrictions de sélection indiquées dans VerbNet. Pour utiliser cette méthode en français, nous traduisons deux ressources lexicales anglaises. Nous commençons par la base de données lexicales WordNet. Nous traduisons ensuite le lexique VerbNet dans lequel les verbes sont regroupés sémantiquement grâce à leurs traits syntaxiques. La traduction, VerbeNet, a été obtenue en réutilisant deux lexiques verbaux du français (le Lexique-Grammaire et Les Verbes Français) puis en modifiant manuellement l'ensemble des informations obtenues. Enfin, une fois ces briques en place, nous évaluons la faisabilité de l'annotation en rôles sémantiques en anglais et en français dans trois domaines spécifiques. Nous évaluons quels sont les avantages et inconvénients de se baser sur VerbNet et VerbeNet pour annoter ces domaines, avant d'indiquer nos perspectives pour poursuivre ces travaux.
These_QuentinPradet_2015-08-15.pdf (1.87 Mo) Télécharger le fichier
tel-01182711 , version 1 (15-08-2015)
Paternité - Partage selon les Conditions Initiales
  • HAL Id : tel-01182711 , version 1
Quentin Pradet. Annotation en rôles sémantiques du français en domaine spécifique. Informatique et langage [cs.CL]. Université Paris Diderot (Paris 7), 2015. Français. ⟨NNT : ⟩. ⟨tel-01182711⟩
460 Consultations
930 Téléchargements
