Étude du rôle des cellules musculaires lisses vasculaires (CMLV) et des anticorps anti-CMLV dans la pathogénie de l’artérite à cellules géantes (maladie de Horton) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2014
Role of vascular smooth muscle cells (VSMC) and anti-VSMC antibodies in the pathogenesis of giant cell arteritis
Background : Giant cell arteritis (GCA) is a large vessel vasculitis and its diagnosis usually relies on the identification of an inflammatory infiltrate made of mononuclear cells and giant cells upon temporal artery biopsy. There is also a remodeling process in the arterial wall due to an excessive proliferation of vascular smooth muscle cells (VSMC) which can sometimes lead to arterial occlusion. Purpose: Identify auto-antibodies targeting either endothelial cells (EC) and/or VSMC during GCA and better understand the role of VSMC in the remodeling process. Methods : Auto-antibodies were detected by a 2-dimensionnal immunoblot and their target antigens were identified by mass spectrometry. Proteoms of umbilical artery, pulmonary artery and aorta VSMC were compared by 2 dimension differential in gel electrophoresis (2D-DIGE). In order to identify mechanisms involved in VSMC proliferation in GCA, we used both 2D-DIGE and pan genomic chips in order to compare VSMC isolated at the time of temporal artery biopsy (TAB) from patients with a final diagnosis of GCA or another diagnosis. Results : In 15 patients with GCA, we identified lamin, vinculin and Annexin A5 as target antigens of anti-VSMC antibodies. Target antigens were linked with Grb2, an adaptator protein involved in VSMC proliferation. Normal VSMC originating from different vascular beds have differ in protein contents with differential expression of cytoskeleton and energy metabolism proteins. We compared VSMC from TAB with Ingenuity software and identified endothelin-1 (ET-1) and paxillin as proteins involved in vessel remodeling. We confirmed by immunohistichemistry and qPCR that ET-1 and its receptor ETAR and ETBR were expressed in temporal arteries from patients with GCA. Last, we reduced VSMC proliferation with Macitentan, an ETAR and ETBR antagonist and significantly inhibited VSMC proliferation with its active metabolite whereas other ET-1 inhibitors had no effect. Conclusion : We identified anti-VSMC auto-antibodies in patients with GCA. Their pathogenic role remains to be determined. Normal VSMC from different vascular locations differ in protein conten which might reflect different phenotypes and different properties. The escessive proliferation of VSMC from patients with GCA was inhibited by Macitentan. This drug might constitute a future therapeutic option.
Rationnel : L’artérite à cellules géantes (ACG) est une vascularite primitive des gros vaisseaux dont le diagnostic repose sur la mise en évidence d’un infiltrat inflammatoire et de cellules géantes à la biopsie d’artère temporale (BAT). On note également un remodelage de la paroi vasculaire lié à une prolifération des cellules musculaires lisses vasculaires (CMLV) pouvant aboutir à une occlusion artérielle. Objectif : Caractériser les auto-anticorps dirigés contre les cellules endothéliales (CE) et les CMLV au cours de l’ACG et préciser le rôle des CMLV dans le remodelage pariétal. Méthodes : La recherche d’auto-anticorps a reposé sur un immunoblot 2D couplé à la spectrométrie de masse. Les protéomes des CMLV d’artère ombilicale, d’artère pulmonaire et d’aorte humaines normales a été comparés par protéomique différentielle (2D-DIGE). Nous avons utilisé la 2D-DIGE et des puces d’expression pan-génomiques pour comparer les CMLV issues de BAT de patients suspects d’ACG (avec un diagnostic final d’ACG ou non), afin d’identifier les mécanismes contribuant à la prolifération des CMLV. Résultats : Chez 15 patients atteints d’ACG, nous avons notamment identifié la lamine, la vinculine et l’annexine A5 comme cible des auto-anticorps anti-CMLV. Les antigènes cibles identifiés sont liés à Grb2, une protéine adaptatrice impliquée dans la prolifération des CMLV. Nous avons mis en évidence des protéomes différents au sein des CMLV humaines normales selon leur origine vasculaire et avons principalement identifié des protéines du cytosquelette et du métabolisme énergétique.A partir des CMLV isolées des BAT et à l’aide d’Ingenuity®, nous avons identifié l’endothéline 1 (ET-1) et la paxilline comme des molécules impliquées dans le remodelage vasculaire. En immunohistochimie et par qPCR, nous avons confirmé l’expression de l’ET-1 et de ses récepteurs ETAR et ETBR au sein des artères temporales de patients atteints d’ACG. Enfin, nous avons inhibé la prolifération des CMLV avec du macitentan, un inhibiteur d’ETAR et en particulier avec son métabolite actif, mais pas avec d’autres inhibiteurs des récepteurs de l’ET-1. Conclusion : Nous avons identifié chez les patients atteints d’ACG des anticorps anti-CMLV dont le rôle pathogéne potentiel reste à définir. Les différences protéiques observées à partir des CMLV humaines normales pourraient correspondre à des phénotypes différents. A partir d’un matériel biologique unique, nous avons pu montrer que la prolifération excessive des CMLV au cours de l’ACG pouvait être inhibée par le macitentan ce qui permet d’envisager un usage thérapeutique de cette molécule.
va_Regent_Alexis.pdf (22.18 Mo) Télécharger le fichier
tel-01191490 , version 1 (02-09-2015)
  • HAL Id : tel-01191490 , version 1
Alexis Régent Régent. Étude du rôle des cellules musculaires lisses vasculaires (CMLV) et des anticorps anti-CMLV dans la pathogénie de l’artérite à cellules géantes (maladie de Horton). Cardiologie et système cardiovasculaire. Université René Descartes - Paris V, 2014. Français. ⟨NNT : 2014PA05S021⟩. ⟨tel-01191490⟩
1045 Consultations
779 Téléchargements
