Estimation of motion from observed objects in image sequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Estimation de la dynamique à partir des structures observées dans une séquence d'images
This thesis describes approaches estimating motion from image sequences with data assimilation methods. A particular attention is given to include representations of the displayed objects in the estimation process. Variational and sequential implementations are discussed in the document.The variational methods rely on an evolution equation, a background equation and an observation equation, which characterize the studied system and the observations. The motion estimation is obtained as the minimum of a cost function. In a first approach, the structures are modeled by their boundaries. The image model describes both the evolution of the gray level function and the displacement of the structures. The resulting motion field should allow the position of the structures in the model to match their observed position. The use of structures betters the result. A second approach, less expensive regarding the computational costs, is designed, where the structures are modeled by the values of the background error covariance matrix.The sequential approach, described in the thesis, relies on the creation of an ensemble of state vectors and on the use of localization methods. In order to model the structures, a new localization criteria based on the gray level values is defined. However, the localization method, if directly applied on the background error covariance matrix, renders the approach inoperable on large images. Therefore, another localization method is designed, which consists to decompose the image domain into independent subdomains before the estimation. Here, the structures representation intervenes while decomposing the global domain.
Cette thèse traite de l'estimation du mouvement à partir d'une séquence d'images par des méthodes d'assimilation de données. Les travaux ont porté sur la prise en compte des objets dans les processus d'estimation, afin de corréler en espace les résultats obtenus. Les deux composantes méthodologiques que sont approche variationnelle et approche séquentielle sont traitées. L'algorithme variationnel repose sur une équation d'évolution, une équation d'ébauche et une équation d'observation. L'estimation s'obtient comme le minimum d'une fonction de coût. Dans une première étape, l'objet est décrit par sa courbe frontière. Le modèle dynamique caractérise l'évolution des images et déplace les objets afin que leurs positions correspondent à celles observées dans les acquisitions image. Cette approche impacte fortement les temps de calculs, mais permet une amélioration de l'estimation du mouvement. Deuxièmement, les valeurs de la matrice de covariance des erreurs d'ébauche sont modifiées afin de corréler, à moindre coût, les pixels de l'image. L'algorithme séquentiel présenté repose sur la création d'un ensemble de vecteurs d'état ainsi que sur des approches de localisation. Pour modéliser les objets, un nouveau critère de localisation portant sur l'intensité de niveau de gris des pixels a été défini. Cependant, la localisation, si elle est appliquée directement sur la matrice de covariance d'erreur, rend la méthode inutilisable pour de grandes images. Une approche consistant à découper le domaine global en sous-domaines indépendants, avant d'estimer le mouvement, a été mise au point. La prise en compte des objets intervient lors du découpage du domaine d'analyse global.
these_archivage_3151563o.pdf (5.08 Mo) Télécharger le fichier
tel-01241514 , version 1 (10-12-2015)
tel-01241514 , version 2 (13-06-2016)
  • HAL Id : tel-01241514 , version 2
Yann Lepoittevin. Estimation of motion from observed objects in image sequences. Biological Physics [physics.bio-ph]. Université Pierre et Marie Curie - Paris VI, 2015. English. ⟨NNT : 2015PA066567⟩. ⟨tel-01241514v2⟩
353 Consultations
328 Téléchargements
