Contributions to the verification and control of timed and probabilistic models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Hdr Année : 2015
The importance of model checking was acknowledged by a Turing award in 2007, and formal methods in general have proved extremely useful in the validation of hardware and software systems. These techniques are based on mathematical abstractions, and require models both of the system, and of the requirements it has to meet. In order to faithfully represent real-life systems, models should incorporate several features including timing contraints, probabilities, unknown parameters and imperfect information. This habilitation document reports on my contributions to formal methods for complex systems that combine several of these aspects. More specifically, the following problems are tackled: approximate determinization of timed automata, model checking and control for stochastic timed automata, synthesis for partially observable probabilistic systems, and parameterized verification of probabilistic systems.
hdr.pdf (861.55 Ko) Télécharger le fichier
tel-01243612 , version 1 (16-12-2015)
  • HAL Id : tel-01243612 , version 1
Nathalie Bertrand. Contributions to the verification and control of timed and probabilistic models: Mémoire d'habilitation à diriger des recherches. Formal Languages and Automata Theory [cs.FL]. Université Rennes 1, 2015. ⟨tel-01243612⟩
490 Consultations
215 Téléchargements
