Réseaux de réactions : de l’analyse probabiliste à la réfutation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Reaction networks : from probabilistic analysis to refutation
A major goal in systems biology is to inverstigate the dynamical behavior of reaction networks. There exists two main dynamical frameworks : the first one is the deterministic dynamics where the dynamics is described using odinary differential equations, the second one is probabilistic and relies on Markov chains. In both cases, one major issue is to determine the kinetic laws of the systems together with its kinetic parameters. As a consequence the direct study of large biological reaction networks is impossible. To deal with this issue, stationnary assumptions have been used. A widely used method is flux balance analysis, where systems of constraints are derived from information on the average slopes of the system trajectories. In this thesis, we construct a probabilistic analog of this stationnary analysis. The results are divided into three parts. First, we introduce a stationnary analysis of the probabilistic dynamics which relies on a Bernoulli approximation. Second, this approximated dynamics allows us to derive systems of constraints from information about the means, variances and co-variances of the system trajectories. Third, we present several applications of these systems of constraints such as the possibility to reject reaction networks using information from experimental variances and co-variances and the formal verification of logical properties concerning the stationnary regime of the system.
L'étude de la dynamique des réseaux de réactions est un enjeu majeur de la biologie des systèmes. Cela peut-être réalisé de deux manières : soit de manière déterministe à l'aide d'équations différentielles, soit de manière probabiliste à l'aide de chaînes de Markov. Dans les deux cas, un problème majeur est celui de la détermination des lois cinétiques impliquées et l'inférence de paramètres cinétiques associés. Pour cette raison, l'étude directe de grands réseaux de réactions est impossible. Dans le cas de la modélisation déterministe, ce problème peut-être contourné à l'aide d'une analyse stationnaire du réseau. Une méthode connue est celle de l'analyse des flux à l'équilibre (FBA) qui permet d'obtenir des systèmes de contraintes à partir d'informations sur les pentes moyennes des trajectoires. Le but de cette thèse est d'introduire une méthode analogue dans le cas de la modélisation probabiliste. Les résultats de la thèse se divisent en trois parties. Tout d'abord on présente une analyse stationnaire de la modélisation probabiliste reposant sur une approximation de Bernoulli. Dans un deuxième temps, cette dynamique approximée nous permet d'établir des systèmes de contraintes à l'aide d'informations obtenues sur les moyennes, les variances et les co-variances des trajectoires du système. Enfin, on présente plusieurs applications à ces systèmes de contraintes telles que la possibilité de réfuter des réseaux de réactions à l'aide d'informations de variances ou de co-variances et la vérification formelle de propriétés logiques sur le régime stationnaire du système.
PICARD_Vincent.pdf (1.31 Mo) Télécharger le fichier
tel-01246180 , version 1 (18-12-2015)
tel-01246180 , version 2 (18-04-2016)
  • HAL Id : tel-01246180 , version 2
Vincent Picard. Réseaux de réactions : de l’analyse probabiliste à la réfutation. Bio-informatique [q-bio.QM]. Université de Rennes, 2015. Français. ⟨NNT : 2015REN1S093⟩. ⟨tel-01246180v2⟩
465 Consultations
564 Téléchargements
