Exploratory Robotic Controllers : An Evolution and Information Theory Driven Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2015
Exploration Robotique Autonome hybridant : évolution et théorie de l'information
This thesis is concerned with building autonomous exploratory robotic controllers in an online, on-board approach, with no requirement for ground truth or human intervention in the experimental setting.This study is primarily motivated by autonomous robotics, specifically autonomous robot swarms. In this context, one faces two difficulties. Firstly, standard simulator-based approaches are hardly effective due to computational efficiency and accuracy reasons. On the one hand, the simulator accuracy is hindered by the variability of the hardware; on the other hand, this approach faces a super-linear computational complexity w.r.t. the number of robots in the swarm. Secondly, the standard goal-driven approach used for controller design does not apply as there is no explicit objective function at the individual level, since the objective is defined at the swarm level.A first step toward autonomous exploratory controllers is proposed in the thesis. The Evolution & Information Theory-based Exploratory Robotics (Ev-ITER) approach is based on the hybridization of two approaches stemming from Evolutionary Robotics and from Reinforcement Learning, with the goal of getting the best of both worlds: (i) primary controllers, or crawling controllers, are evolved in order to generate sensori-motor trajectories with high entropy; (ii) the data repository built from the crawling controllers is exploited, providing prior knowledge to secondary controllers, inspired from the intrinsic robust motivation setting and achieving the thorough exploration of the environment.The contributions of the thesis are threefold. Firstly, Ev-ITER fulfills the desired requirement: it runs online, on-board and without requiring any ground truth or support. Secondly, Ev-ITER outperforms both the evolutionary and the information theory-based approaches standalone, in terms of actual exploration of the arena. Thirdly and most importantly, the Ev-ITER controller features some generality property, being able to efficiently explore other arenas than the one considered during the first evolutionary phase. It must be emphasized that the generality of the learned controller with respect to the considered environment has rarely been considered, neither in the reinforcement learning, nor in evolutionary robotics.
Cette thèse porte sur la conception de contrôleurs pour robots explorateurs autonomes basée sur une approche en ligne (online) intégrée, ne nécessitant pas de vérité terrain ni d'intervention de l'expert humain au cours du processus d'entrainement.Le travail présenté se focalise sur le domaine de la robotique autonome et plus particulièrement la conception de controleurs robotiques pour les essaims de robots.Ce contexte présente deux difficultés spécifiques. Premièrement, les approches basées sur l'usage de simulateur sont d'efficacité limitée : d'une part, la précision du simulateur est limitée compte tenu de la variabilité des robots élémentaires; d'autre part, la complexité de la simulation est super-linéaire en fonction du nombre de robots de l'essaim. Deuxièmement, les approches guidées par le but se heurtent au fait que la fonction objectif n'est pas définie au niveau du robot individuel, mais au niveau de l'essaim.Une première étape vers la conception de contrôleur explorateur autonome est proposée dans cette thèse. L'approche proposée, appelée exploration robotique fondée sur l'évolution et l'information (Ev-ITER) se fonde sur l'hybridation de la robotique évolutionnaire et de l'apprentissage par renforcement utilisant l'entropie. Cette approche procède en deux phases: (i) dans une première phase l'évolution artificielle est utilisée pour générer des contrôleurs primaires (crawlers), dont les trajectoires sont d'entropie élevée dans l'espace sensori-moteur; (ii) dans une seconde phase, l'archive des trajectoires acquises par les controleurs primaires est exploitée pour définir les controleurs secondaires, inspirés de la motivation intrinsèque robuste et permettant l'exploration rigoureuse de l'environnement.Les contributions de cette thèse sont les suivantes. Premièrement, comme désiré Ev-ITER peut être lancé en ligne, et sans nécessiter de vérité terrain ou d'assistance. Deuxièmement, Ev-ITER surpasse les approches autonomes en robotique évolutionnaire en terme d'exploration de l'arène. Troisièmement, le contrôleur Ev-ITER est doté d'une certaine généralité, dans la mesure où il est capable d'explorer efficacement d'autres arènes que celle considérée pendant la première phase de l'évolution. Il est à souligner que la généralité du contrôleur appris vis-à-vis de l'environnement d'entrainement a rarement été considérée en apprentissage par renforcement ou en robotique évolutionnaire.
VA2_ZHANG_GUOHUA_24092015.pdf (2.45 Mo) Télécharger le fichier
tel-01280059 , version 1 (29-02-2016)
  • HAL Id : tel-01280059 , version 1
Guohua Zhang. Exploratory Robotic Controllers : An Evolution and Information Theory Driven Approach. Robotics [cs.RO]. Université Paris Sud - Paris XI, 2015. English. ⟨NNT : 2015PA112208⟩. ⟨tel-01280059⟩
662 Consultations
712 Téléchargements
