A compact video representation format based on spatio-temporal linear embedding and epitome - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Un format de représentation vidéo compact basé sur des plongements linéaires et des épitomes
Efficient video compression is nowadays a critical issue, and is expected to be more and more crucial in the future, with the ever increasing video traffic and the production of new digital video formats with high resolution, wide color gamut, high dynamic range, or high frame rate. The MPEG standard HEVC is currently one of the most efficient video compression scheme, however, addressing the future needs calls for novel and disruptive methods. In fact, the main principles of modern video compression standards rely on concepts designed more than 30 years ago: the reduction of spatial and temporal redundancies, through prediction tools, the use of a transform to further reduce the inner correlations of the signal, followed by quantization to remove non-perceptive information, and entropy coding to remove the remaining statistical redundancies. In this thesis, we explore novel methods which aims at further exploiting the natural redundancies occurring in video signals, notably through the use of multi-patches techniques. First, we introduce LLE-based multi-patches methods in order to improve Inter prediction, which are then combined for both Intra and Inter predictions, and are proven efficient over H.264. We then propose epitome-based de-noising methods to improve the performances of existing codecs in a out-of-the-loop scheme. High quality epitomes are transmitted to the decoder in addition to the coded sequence, and we can then use at the decoder side multi-patches de-noising methods relying on the high quality patches from the epitomes, in order to improve the quality of the decoded sequence. This scheme is shown efficient compared to SHVC. Finally, we proposed another out-of-the-loop scheme relying on a symmetric clustering of the patches performed at both encoder and decoder sides. At the encoder side, linear mappings are learned for each cluster between the coded/decoded patches and the corresponding source patches. The linear mappings are then sent to the decoder and applied to the decoded patches in order to improve the quality of the decoded sequence. The proposed scheme improves the performances of HEVC, and is shown promising for scalable schemes such as SHVC.
L'efficacité des services de compression vidéo est de nos jours un enjeu essentiel, et est appelé à le devenir d'autant plus dans le futur, comme l'indique la croissance constante du trafic vidéo et la production de nouveaux formats tels que la vidéo à haute résolution, à gamme de couleur ou dynamique étendues, ou encore à fréquence d'images augmentée. Le standard MPEG HEVC est aujourd'hui un des schémas de compression les plus efficaces, toutefois, il devient nécessaire de proposer de nouvelles méthodes originales pour faire face aux nouveaux besoins de compression. En effet, les principes de bases des codecs modernes ont été conçu il y a plus de 30 ans : la réduction des redondances spatiales et temporelles du signal en utilisant des outils de prédiction, l'utilisation d'une transformée afin de diminuer d'avantage les corrélations du signal, une quantification afin de réduire l'information non perceptible, et enfin un codage entropique pour prendre en compte les redondances statistiques du signal. Dans cette thèse, nous explorons de nouvelles méthodes ayant pour but d'exploiter d'avantage les redondances du signal vidéo, notamment à travers des techniques multi-patchs. Dans un premier temps, nous présentons des méthodes multi-patchs basées LLE pour améliorer la prédiction Inter, qui sont ensuite combinées pour la prédiction Intra et Inter. Nous montrons leur efficacité comparé à H.264. La seconde contribution de cette thèse est un schéma d'amélioration en dehors de la boucle de codage, basé sur des méthodes de débruitage avec épitome. Des épitomes de bonne qualité sont transmis au décodeur en plus de la vidéo encodée, et nous pouvons alors utiliser coté décodeur des méthodes de débruitage multi-patchs qui s'appuient sur les patchs de bonne qualité contenu dans les épitomes, afin d'améliorer la qualité de la vidéo décodée. Nous montrons que le schéma est efficace en comparaison de SHVC. Enfin, nous proposons un autre schéma d'amélioration en dehors de la boucle de codage, qui s'appuie sur un partitionnement des patchs symétrique à l'encodeur et au décodeur. Coté encodeur, on peut alors apprendre des projections linéaires pour chaque partition entre les patchs codés/décodés et les patchs sources. Les projections linéaires sont alors envoyés au décodeur et appliquées aux patchs décodés afin d'en améliorer la qualité. Le schéma proposé est efficace comparé à HEVC, et prometteur pour des schémas scalables comme SHVC.
ALAIN_Martin.pdf (15.31 Mo) Télécharger le fichier
tel-01261590 , version 1 (25-01-2016)
tel-01261590 , version 2 (07-03-2016)
  • HAL Id : tel-01261590 , version 2
Martin Alain. A compact video representation format based on spatio-temporal linear embedding and epitome. Signal and Image processing. Université de Rennes, 2016. English. ⟨NNT : 2016REN1S001⟩. ⟨tel-01261590v2⟩
363 Consultations
585 Téléchargements
