Synthèse et compilation de services web sécurisés - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2011
Automatic synthesis of secured web services
Automatic composition of web services is a challenging task. Many works have considered simplified automata models that abstract away from the structure of messages exchanged by the services. For the domain of secured services (using e.g. digital signing or timestamping) we propose a novel approach to automated composition of services based on their security policies. Given a community of services and a goal service, we reduce the problem of composing the goal from services in the community to a security problem where an intruder should intercept and redirect messages from the service community and a client service till reaching a satisfying state. We have implemented the algorithm in Avantssar Platform and applied the tool to several case studies. Then we present a tool that compiles the obtained trace describing the execution of a the mediator into its corresponding runnable code. For that we first compute an executable specification as prudent as possible of her role in the orchestration. This specification is expressed in ASLan language, a formal language designed for modeling Web Services tied with security policies. Then we can check with automatic tools that this ASLan specification verifies some required security properties such as secrecy and authentication. If no flaw is found, we compile the specification into a Java servlet that can be used by the mediator to lead the orchestration.
La composition automatique de services web est une tâche difficile. De nombreux travaux ont considérés des modèles simplifiés d'automates qui font abstraction de la structure des messages échangés par les services. Pour le domaine des services sécurisés (par exemple utilisant la signature numérique ou l'horodatage), nous proposons une nouvelle approche pour automatiser la composition des services basés sur leurs politiques de sécurité. Étant donnés, une communauté de services et un service objectif, nous réduisons le problème de la synthèse de l'objectif à partir des services dans la communauté à un problème de sécurité, où un intrus doit intercepter et rediriger les messages depuis et vers la communauté de services et un service client jusqu'à atteindre un état satisfaisant pour le dernier. Nous avons implémenté notre algorithme dans la plateforme de validation du projet AVANTSSAR et nous avons testé l'outil correspondant sur plusieurs études de cas. Ensuite, nous présentons un outil qui compile les traces obtenues décrivant l'exécution d'un médiateur vers le code exécutable correspondant. Pour cela nous calculons d'abord une spécification exécutable aussi prudente que possible de son rôle dans l'orchestration. Cette spécification est exprimé dans la langue ASLan, un langage formel conçu pour la modélisation des services Web liés à des politiques de sécurité. Ensuite, nous pouvons vérifier avec des outils automatiques que la spécification ASLan obtenue vérifie certaines propriétés requises de sécurité telles que le secret et l'authentification. Si aucune faille n'est détectée, nous compilons la spécification ASLan vers une servlet Java qui peut être utilisé par le médiateur pour contrôler l'orchestration.
SCD_T_2011_0123_MEKKI.pdf (3.2 Mo) Télécharger le fichier
tel-01293742 , version 1 (25-03-2016)
  • HAL Id : tel-01293742 , version 1
Mohammed Anis Mekki. Synthèse et compilation de services web sécurisés . Informatique [cs]. Universite de Lorraine, 2011. Français. ⟨NNT : ⟩. ⟨tel-01293742⟩
220 Consultations
67 Téléchargements
