Abstract : The recent increase of data volumes raises new challenges for itemset mining
algorithms. In this thesis, we focus on transactional datasets (collections of items
sets, for example supermarket tickets) containing at least a million transactions
over hundreds of thousands items. These datasets usually follow a “long tail”
distribution: a few items are very frequent, and most items appear rarely. Such
distributions are often truncated by existing itemset mining algorithms, whose
results concern only a very small portion of the available items (the most frequents,
usually). Thus, existing methods fail to concisely provide relevant insights on large
datasets. We therefore introduce a new semantics which is more intuitive for the
analyst: browsing associations per item, for any item, and less than a hundred
associations at once.
To address the items’ coverage challenge, our first contribution is the item-
centric mining problem. It consists in computing, for each item in the dataset,
the k most frequent closed itemsets containing this item. We present an algorithm
to solve it, TopPI. We show that TopPI computes efficiently interesting results
over our datasets, outperforming simpler solutions or emulations based on existing
algorithms, both in terms of run-time and result completeness. We also show and
empirically validate how TopPI can be parallelized, on multi-core machines and
on Hadoop clusters, in order to speed-up computation on large scale datasets.
Our second contribution is CAPA, a framework allowing us to study which
existing measures of association rules’ quality are relevant to rank results. This
concerns results obtained from TopPI or from j LCM, our implementation of a
state-of-the-art frequent closed itemsets mining algorithm (LCM). Our quantita-
tive study shows that the 39 quality measures we compare can be grouped into
5 families, based on the similarity of the rankings they produce. We also involve
marketing experts in a qualitative study, in order to discover which of the 5 families
we propose highlights the most interesting associations for their domain.
Our close collaboration with Intermarché, one of our industrial partners in the
Datalyse project, allows us to show extensive experiments on real, nation-wide
supermarket data. We present a complete analytics workflow addressing this use
case. We also experiment on Web data. Our contributions can be relevant in
various other fields, thanks to the genericity of transactional datasets.
Altogether our contributions allow analysts to discover associations of interest
in modern datasets. We pave the way for a more reactive discovery of items’ asso-
ciations in large-scale datasets, whether on highly dynamic data or for interactive
exploration systems.
Résumé : Les algorithmes actuels pour la fouille d’ensembles fréquents sont dépassés par
l’augmentation des volumes de données. Dans cette thèse nous nous intéressons
plus particulièrement aux données transactionnelles (des collections d’ensembles
d’objets, par exemple des tickets de caisse) qui contiennent au moins un mil-
lion de transactions portant sur au moins des centaines de milliers d’objets. Les
jeux de données de cette taille suivent généralement une distribution dite en
“longue traine”: alors que quelques objets sont très fréquents, la plupart sont
rares. Ces distributions sont le plus souvent tronquées par les algorithmes de
fouille d’ensembles fréquents, dont les résultats ne portent que sur une infime
partie des objets disponibles (les plus fréquents). Les méthodes existantes ne per-
mettent donc pas de découvrir des associations concises et pertinentes au sein
d’un grand jeu de données. Nous proposons donc une nouvelle sémantique, plus
intuitive pour l’analyste: parcourir les associations par objet, au plus une centaine
à la fois, et ce pour chaque objet présent dans les données.
Afin de parvenir à couvrir tous les objets, notre première contribution consiste
à définir la fouille centrée sur les objets. Cela consiste à calculer, pour chaque
objet trouvé dans les données, les k ensembles d’objets les plus fréquents qui le
contiennent. Nous présentons un algorithme effectuant ce calcul, TopPI. Nous
montrons que TopPI calcule efficacement des résultats intéressants sur nos jeux
de données. Il est plus performant que des solutions naives ou des émulations
reposant sur des algorithmes existants, aussi bien en termes de rapidité que de
complétude des résultats. Nous décrivons et expérimentons deux versions par-
allèles de TopPI (l’une sur des machines multi-coeurs, l’autre sur des grappes
Hadoop) qui permettent d’accélerer le calcul à grande échelle.
Notre seconde contribution est CAPA, un système permettant d’étudier quelle
mesure de qualité des règles d’association serait la plus appropriée pour trier nos
résultats. Cela s’applique aussi bien aux résultats issus de TopPI que de j LCM,
notre implémentation d’un algorithme récent de fouille d’ensembles fréquents fer-
més (LCM). Notre étude quantitative montre que les 39 mesures que nous com-
parons peuvent être regroupées en 5 familles, d’après la similarité des classements
de règles qu’elles produisent. Nous invitons aussi des experts en marketing à par-
ticiper à une étude qualitative, afin de déterminer laquelle des 5 familles que nous
proposons met en avant les associations d’objets les plus pertinentes dans leur
domaine.
Notre collaboration avec Intermarché, partenaire industriel dans le cadre du
projet Datalyse, nous permet de présenter des expériences complètes et por-
tant sur des données réelles issues de supermarchés dans toute la France. Nous
décrivons un flux d’analyse complet, à même de répondre à cette application. Nous
présentons également des expériences portant sur des données issues d’Internet;
grâce à la généricité du modèle des ensembles d’objets, nos contributions peuvent
s’appliquer dans d’autres domaines.
Nos contributions permettent donc aux analystes de découvrir des associations
d’objets au milieu de grandes masses de données. Nos travaux ouvrent aussi la
voie vers la fouille d’associations interactive à large échelle, afin d’analyser des
données hautement dynamiques ou de réduire la portion du fichier à analyser à
celle qui intéresse le plus l’analyste.
