New interface
Theses
Techniques d'interaction, affichage personnalisé et reconstruction de surfaces pour la réalité augmentée spatiale.
Brett Ridel 1, 2
1 MANAO - Melting the frontiers between Light, Shape and Matter
LaBRI - Laboratoire Bordelais de Recherche en Informatique, Inria Bordeaux - Sud-Ouest, LP2N - Laboratoire Photonique, Numérique et Nanosciences
Abstract : This thesis extends the field of spatial augmented reality (SAR). Spatial augmented reality allows to improve or modify the perception of the reality with virtual information displayed directly in the real world, using video-projection. Many fields such as tourism, entertainment, education, medicine, industry or cultural heritage may benefit from it. Recent computer science techniques allow to measure, analyse and visualise the geometry of the surface of real objects, as for instance archeological artefacts. We propose a SAR interaction and visualisation technique that combines the advantages of the study of both real and 3D archeological artefacts. Thus, we superimpose on the object an expressive rendering based on curvatures with SAR, allowing for example to show details of engravings. Next, we simulate the use of a flashlight with the help of a 6-degree-of-freedom controller. The user can then specify the area on the object to be augmented and adjust the various necessary parameters of the expressive rendering. One of the main caracteristics of SAR is to enable multiple users to simultaneously participate to the same experience. However, depending on the target application, this can be seen as a drawback. We propose a new display device that allows to create experiences in SAR that are both multiuser and personalised by taking into account the user point of view. In order to do so, the projection display, set in front of the object to augment, is made from a material that is both retro-reflective and semi-transparent. We suggest two different uses of this new device, as well as two scenarios of application. Most of recent tracking solutions, even with the knowledge of the geometry of the object beforehand, fail when applied to the augmentation of deformable objects. In order to adress this issue, we propose a reconstruction technique for developable surfaces using parabolic-cylinders based on MLS. This kind of surface may represent cloth or fabric for instance. We show a solution addressing approximation issues in areas where the problem becomes ambiguous.
Document type :
Theses
Complete list of metadata
Cited literature [179 references]  Display  Hide  Download
https://hal.inria.fr/tel-01414792
Contributor : Brett Ridel Connect in order to contact the contributor
Submitted on : Monday, December 12, 2016 - 3:37:37 PM
Last modification on : Sunday, October 30, 2022 - 8:39:38 PM
Long-term archiving on: : Monday, March 27, 2017 - 8:00:24 PM
Identifiers
  • HAL Id : tel-01414792, version 1
Collections
Citation
Brett Ridel. Techniques d'interaction, affichage personnalisé et reconstruction de surfaces pour la réalité augmentée spatiale.. Interface homme-machine [cs.HC]. Université de bordeaux, 2016. Français. ⟨NNT : ⟩. ⟨tel-01414792⟩
Share
Metrics
Record views
321
Files downloads
573
