Data Aggregation in Wireless Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Agrégation de données dans les réseaux de capteurs sans fil
Jin Cui
  • Fonction : Auteur
  • PersonId : 957392
Wireless Sensor Networks (WSNs) have been regarded as an emerging and promis- ing field in both academia and industry. Currently, such networks are deployed due to their unique properties, such as self-organization and ease of deployment. How- ever, there are still some technical challenges needed to be addressed, such as energy and network capacity constraints. Data aggregation, as a fundamental solution, pro- cesses information at sensor level as a useful digest, and only transmits the digest to the sink. The energy and capacity consumptions are reduced due to less data packets transmission. As a key category of data aggregation, aggregation function, solving how to aggregate information at sensor level, is investigated in this thesis. We make four main contributions: firstly, we propose two new networking-oriented metrics to evaluate the performance of aggregation function: aggregation ratio and packet size coefficient. Aggregation ratio is used to measure the energy saving by data aggregation, and packet size coefficient allows to evaluate the network capac- ity change due to data aggregation. Using these metrics, we confirm that data ag- gregation saves energy and capacity whatever the routing or MAC protocol is used. Secondly, to reduce the impact of sensitive raw data, we propose a data-independent aggregation method which benefits from similar data evolution and achieves better re- covered fidelity. Thirdly, a property-independent aggregation function is proposed to adapt the dynamic data variations. Comparing to other functions, our proposal can fit the latest raw data better and achieve real adaptability without assumption about the application and the network topology. Finally, considering a given application, a tar- get accuracy, we classify the forecasting aggregation functions by their performances. The networking-oriented metrics are used to measure the function performance, and a Markov Decision Process is used to compute them. Dataset characterization and classification framework are also presented to guide researcher and engineer to select an appropriate functions under specific requirements.
Depuis plusieurs années, les réseaux de capteurs sans fil sont considérés comme un domaine émergent et prometteur tant dans le milieu universitaire que dans l’industrie. De tels réseaux ont déjà été largement déployés en raison de leurs propriétés clés, telles que l’auto-organisation et leur autonomie en énergie. Cependant, il reste de nombreux défis scientifiques telles que la réduction de la consommation d’énergie sur des capteurs de plus en plus petits et la capacité du réseau tenant compte de liens à bande passante réduite. Selon nous, l’agrégation de données apparaît comme une so- lution pour ces deux défis, car au lieu d’envoyer une donnée, l’agrégation va traiter les informations collectées au niveau du capteur et produire une donnée agrégée qui sera effectivement transmise au puits. L’énergie et la capacité du réseau seront donc économisées car il y aura moins de transmissions de données. Le travail de cette thèse s’intéresse principalement aux fonctions d’agrégation Nous faisons quatre contributions principales. Tout d’abord, nous proposons deux nouvelles métriques pour évaluer les performances des fonctions d’agrégations vue au niveau réseau : le taux d’agrégation et le facteur d’accroissement de la taille des paquets. Le taux d’agrégation est utilisé pour mesurer le gain de paquets non trans- mis grâce à l’agrégation tandis que le facteur d’accroissement de la taille des pa- quets permet d’évaluer la variation de la taille des paquets en fonction des politiques d’agrégation. Ces métriques permettent de quantifier l’apport de l’agrégation dans l’économie d’énergie et de la capacité utilisée en fonction du protocole de routage con- sidéré et de la couche MAC retenue. Deuxièmement, pour réduire l’impact des don- nées brutes collectées par les capteurs, nous proposons une méthode d’agrégation de données indépendante de la mesure physique et basée sur les tendances d’évolution des données. Nous montrons que cette méthode permet de faire une agrégation spa- tiale efficace tout en améliorant la fidélité des données agrégées. En troisième lieu, et parce que dans la plupart des travaux de la littérature, une hypothèse sur le com- portement de l’application et/ou la topologie du réseau est toujours sous-entendue, nous proposons une nouvelle fonction d’agrégation agnostique de l’application et des données devant être collectées. Cette fonction est capable de s’adapter aux données mesurées et à leurs évolutions dynamiques. Enfin, nous nous intéressons aux outils pour proposer une classification des fonctions d’agrégation. Autrement dit, consid- érant une application donnée et une précision cible, comment choisir les meilleures fonctions d’agrégations en termes de performances. Les métriques, que nous avons proposé, sont utilisées pour mesurer la performance de la fonction, et un processus de décision markovien est utilisé pour les mesurer. Comment caractériser un ensem- ble de données est également discuté. Une classification est proposée dans un cadre précis.
jin_thesis.pdf (6.45 Mo) Télécharger le fichier
tel-01428983 , version 1 (06-01-2017)
  • HAL Id : tel-01428983 , version 1
Jin Cui. Data Aggregation in Wireless Sensor Networks. Networking and Internet Architecture [cs.NI]. INSA Lyon, 2016. English. ⟨NNT : ⟩. ⟨tel-01428983⟩
534 Consultations
1899 Téléchargements
