Approche multimodale pour la conception d'interfaces à retour tactile à plusieurs doigts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2016
Multimodal approach for the design of a multi touch tactile feedback interface
Tactile display devices are used for providing tactile feedback to their users. They can reproduce the illusion of textured surface by controlling the friction between a vibrating surface and a sliding finger on it. For most of these devices, the basic principle is to use a single resonant mode whose frequency and wave form are imposed by the nature of the material and the geometry of the device. The mode is selected to achieve a homogeneous stimulation, and thereby tactile sensation is undifferentiated over the entire surface. The single mode tactile devices are limited for applications which require more varied information on surface. This work introduces a novel approach for tactile feedback based on the superposition of several vibration modes. The modes are excited simultaneously to perform a more complex wave form and are capable to generate multitouch tactile feedback. This approach has been validated for the case of a beam where two vibration modes were superimposed to generate a differentiated tactile simulation with two fingers. Thanks to vector control method applied to a piezoacturator. A tracking system was implemented to give a multitouch illusion based on the positions of the two fingers. This multimodal approach was later extended to the case of a thin plate where different spatial distributions of the displacement have been imposed, which causes different friction coefficients over the entire surface of the structure. The approach developed in this work is also capable to generate and control a travelling wave amplitude and direction. For this reason, we evaluated the interest of travelling waves in touch interfaces. The achieved results show that it is possible to obtain two different sensations according to the controlled direction of travelling wave. Psychophysical assessments of proposed devices clearly show the interest to use several vibration modes in tactile feedback simulation.
Les dispositifs à retour tactile sont utilisés pour créer un retour sensoriel à leurs utilisateurs. Par exemple, il est possible de reproduire sous le doigt l'illusion de surfaces texturées par le contrôle de la friction entre une surface mise en vibration et le doigt de l'utilisateur parcourant la dalle. Pour la plupart de ces dispositifs, le principe de base consiste à utiliser un mode de résonance dont la fréquence et la forme sont imposées par la nature du matériau et la géométrie du dispositif. Le mode est sélectionné pour réaliser une stimulation homogène, et de ce fait elle est indifférenciée sur l'ensemble de la surface. En regard de certaines applications demandant une information plus variée, c'est un facteur limitant. On propose dans ce travail de thèse une nouvelle approche, basée sur la superposition de plusieurs modes de vibration. Les modes sont excités simultanément pour réaliser des déformées plus complexes et modulables, afin de générer une simulation à retour tactile multitouch. Cette approche a été validée pour le cas d'une poutre où deux modes de vibration ont été superposés pour générer une simulation tactile différenciée sous deux doigts, grâce au contrôle vectoriel de deux actionneurs piézoélectriques. Un système de suivi a été implémenté pour donner une illusion multitouch en fonction de la position des deux doigts. Cette approche multimodale a été ensuite étendue au cas d'une plaque mince où différentes distributions spatiales du déplacement ont été imposées, ce qui provoque différents coefficients de frottement sur toute la surface de la structure. L'approche développée dans ce travail nous a permis également de générer et de contrôler une onde progressive en amplitude et en direction. Pour cette raison, nous avons évalué l'intérêt des ondes progressives dans les interfaces tactiles. Les résultats ont montré la possibilité d'obtenir deux sensations différentes selon la direction contrôlée de l'onde progressive. Les évaluations psychophysiques des dispositifs proposés dans ce travail, montrent clairement l'intérêt d'exploiter plusieurs modes de vibration pour une simulation à retour tactile.
Thèse_Sofiane_GHENNA.pdf (30.12 Mo) Télécharger le fichier
tel-01526451 , version 1 (23-05-2017)
  • HAL Id : tel-01526451 , version 1
Sofiane Ghenna. Approche multimodale pour la conception d'interfaces à retour tactile à plusieurs doigts. Sciences de l'ingénieur [physics]. Université Lille 1 - Sciences et Technologies, 2016. Français. ⟨NNT : ⟩. ⟨tel-01526451⟩
224 Consultations
159 Téléchargements
