Consistency of statistics in infinite dimensional quotient spaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Thèse Année : 2017
Consistance des statistiques dans les espaces quotients de dimension infinie
In computational anatomy, organ shapes are assumed to be deformation of a common template. The data can be organ images but also organ surfaces, and the deformations are often assumed to be diffeomorphisms. In order to estimate the template, one often uses the max-max algorithm which minimizes, among all the prospective templates, the sum of the squared distance after registration between the data and a prospective template. Registration is here the step of the algorithm which finds the best deformation between two shapes. The goal of this thesis is to study this template estimation method from a mathematically point of view. We prove in particular that this algorithm is inconsistent due to the noise. This means that even with an infinite number of data, and with a perfect minimization algorithm, one estimates the original template with an error. In order to prove inconsistency, we formalize the template estimation: deformations are assumed to be random elements of a group which acts on the space of observations. Besides, the studied algorithm is interpreted as the computation of the Fréchet mean in the space of observations quotiented by the group of deformations. In this thesis, we prove that the inconsistency comes from the contraction of the distance in the quotient space with respect to the distance in the space of observations. Besides, we obtained a Taylor expansion of the consistency bias with respect to the noise level. As a consequence, the inconsistency is unavoidable when the noise level is high.
En anatomie computationnelle, on suppose que les formes d'organes sont issues des déformations d'un template commun. Les données peuvent être des images ou des surfaces d'organes, les déformations peuvent être des difféomorphismes. Pour estimer le template, on utilise souvent un algorithme appelé «max-max» qui minimise parmi tous les candidats, la somme des carrées des distances après recalage entre les données et le template candidat. Le recalage est l'étape de l'algorithme qui trouve la meilleure déformation pour passer d'une forme à une autre. Le but de cette thèse est d'étudier cet algorithme max-max d'un point de vue mathématique. En particulier, on prouve que cet algorithme est inconsistant à cause du bruit. Cela signifie que même avec un nombre infini de données et avec un algorithme de minimisation parfait, on estime le template original avec une erreur non nulle. Pour prouver l'inconsistance, on formalise l'estimation du template. On suppose que les déformations sont des éléments aléatoires d'un groupe qui agit sur l'espace des observations. L'algorithme étudié est interprété comme le calcul de la moyenne de Fréchet dans l'espace des observations quotienté par le groupe des déformations. Dans cette thèse, on prouve que l'inconsistance est dû à la contraction de la distance quotient par rapport à la distance dans l'espace des observations. De plus, on obtient un équivalent de biais de consistance en fonction du niveau de bruit. Ainsi, l'inconsistance est inévitable quand le niveau de bruit est suffisamment grand.
2017AZUR4103.pdf (3.64 Mo) Télécharger le fichier
tel-01683607 , version 1 (14-01-2018)
tel-01683607 , version 2 (21-02-2018)
  • HAL Id : tel-01683607 , version 2
Loïc Devilliers. Consistency of statistics in infinite dimensional quotient spaces. Other. Université Côte d'Azur, 2017. English. ⟨NNT : 2017AZUR4103⟩. ⟨tel-01683607v2⟩
600 Consultations
329 Téléchargements
