Abstract : Natural Language Processing (NLP) systems are continuously faced with the problem of generating
concurrent hypotheses, of which some can be erroneous. In order to avoid the propagation of erroneous
hypotheses, it appears to be essential to apply specific control strategies, which aim to distinguishing
concurrent hypotheses based on their relevance.
On most of observed indetermination cases, we have noticed that multiple heterogeneous knowledge
sources have to be combined to determine the hypotheses relative relevance. According to this observation,
we show that the control of the indetermination cases can be formalised as a decisional process based on
multiple criteria.
This decisional formalisation and our research of an adapted methodology have conducted us toward
an outranking approach issued from the MultiCriteria Decision Aid (MCDA) paradigm. This approach
differs from alternative methods by the importance granted to knowledge and preferences that an expert
can express about a given problem.
From this innovative intersection between NLP and MCDA, our work has been focalised on the
development of a decisional module dedicated to multicriteria control. The integration of this module
into a complete NLP system has allowed us to attest the feasibility of our approach and to perform
experimentation on concrete indetermination cases.
Résumé : Les systèmes de Traitement Automatique des Langues Naturelles (TALN) sont de manière récurrente
confrontés au problème de la génération et de la propagation d’hypothèses concurrentes et erronées. Afin
d’écarter ces erreurs d’interprétation du processus d’analyse, il apparaît indispensable d’avoir recours à des
stratégies spécifiques de contrôle dont l’objectif est de différencier les hypothèses concurrentes selon leur
degré de pertinence. Sur la plupart des cas d’indétermination observés, on constate que cette évaluation
de la pertinence relative des hypothèses repose sur l’exploitation de plusieurs sources de connaissances
hétérogènes, qui doivent être combinées pour garantir un contrôle robuste et fiable. À partir de ce constat,
nous avons montré que le traitement des indéterminations répondait à une formalisation générique en tant
que problème décisionnel basé sur de multiples critères de comparaison. Cette formalisation et la recherche
d’une méthodologie adaptée nous ont conduit vers une approche par surclassement issue des travaux en
Aide MultiCritère à la Décision (AMCD). Par rapport aux méthodes alternatives, cette approche se
différentie notamment par l’importance qu’elle accorde aux connaissances et préférences qu’un expert est
en mesure d’apporter sur le problème traité.
À partir de cette intersection novatrice entre le TALN et l’AMCD, nos travaux se sont focalisés sur
le développement d’un module décisionnel de contrôle multicritère. L’intégration de ce module au sein
d’un système complet de TALN nous a permis d’attester d’une part la faisabilité de notre approche et
d’autre part de l’expérimenter sur différents cas concrets d’indétermination.
