“La plume en l’absence" : familiar verse epistles in early printed poetry collections (1527-1555) - Archive ouverte HAL Access content directly
Theses Year : 2017
« La plume en l'absence » : le devenir familier de l'épître en vers dans les recueils imprimés de poésie (1527-1555)
(1)
1
This dissertation offers to uncover how, between 1527 and 1555, the establishment of the French verse epistle as a poetic genre paradoxically happened through a diminishing of its status, from the prestigious Ovidian héroïde to the “low” familiar type criticized by Du Bellay in his Deffence et Illustration de la langue Françoise (1549). It argues that the marotique-type printed collections, which are built around the assertion of a strong auctorial figure, played a great part in this transformation, as they proved to be a designated supporting medium for the “personalization” of the epistle. The first part of this thesis analyzes from a diachronic perspective the interplay between the poetic establishment of the genre and its anthologization: this led to the singling out of a first period in which poets explored the genre through the debuting medium of the recueil d’auteur (1527-1532), a second period that consecrated the printed familiar epistle (1532-1549) and a third period during which epistles’ authors redefined the genre in order to challenge Du Bellay (1549-1555). The next part investigates the way printed epistolary collections reflect a specific image of the genre, which asserts itself by highlighting its own modest status, whether this means hiding its Horatian background, emphasizing the humble social status of the poet or elaborating a decorum that revolves around marginality. Finally, a third part analyzes the dispositio of several emblematic epistolary collections, arguing that the order through which the epistles were displayed was orientating the readers’ reception of the genre as well as expressing the singularity of the epistolary poetics elaborated by our authors.
Cette thèse se propose d’étudier comment, entre 1527 et 1555, l’affermissement de l’épître en vers à l’intérieur du champ poétique s’est produit par une diminution paradoxale de son statut, depuis le prestige de l’héroïde ovidienne jusqu’à la forme modeste et familière dépréciée par Du Bellay dans la Deffence et Illustration de la langue Françoise (1549). Lieux de construction d’une figure auctoriale affirmée, les recueils d’auteur ont constitué le medium privilégié de cette « personnalisation » du genre épistolaire. Dans une première partie, une analyse diachronique révèle qu’aux balbutiements imprimés de l’épître personnelle (1527-1532) succède une période d’hégémonie éditoriale du modèle familier (1532-1549), avant que la diffusion imprimée de l’épître ne soit corrélée à la défense d’une poétique « marotique » (1549-1555). La deuxième partie examine les représentations de l’épître personnelle à l’intérieur du corpus : celle-ci s’affirme en exhibant sa modestie, que ce soit par la revendication d’un intertexte récent, par l’élaboration d’un decorum soulignant la marginalité du poète ou par la mise en œuvre d’une poétique du sermo. La troisième partie articule les approches matérielle et poétique pour monter comment la dispositio des sections épistolaires donne à voir le surgissement d’une familiarité débordant les principes de composition chronologiques et hiérarchiques, en même temps qu’elle exprime la singularité de cette nouvelle poétique épistolaire.
These_DORIO_Pauline_2017.pdf (4.83 Mo) Télécharger le fichier
Origin : Version validated by the jury (STAR)
Dates and versions
tel-01790251 , version 1 (11-05-2018)
Identifiers
  • HAL Id : tel-01790251 , version 1
Cite
Pauline Dorio. « La plume en l'absence » : le devenir familier de l'épître en vers dans les recueils imprimés de poésie (1527-1555). Littératures. Université Sorbonne Paris Cité, 2017. Français. ⟨NNT : 2017USPCA036⟩. ⟨tel-01790251⟩
632 View
666 Download
Share
